BTW, is that a 400r bar on your r33? i'd love to see what that bumper looks like in the flesh, i like the look of the extra vents on the side.
Yep, it's a 400R bar.. I'll PM you some better pics
  • Replies 80
Posted Images
I can't believe some of you people are giving the Veyron shit!! It's simply the overall best car ever built.... as for not having a "proper" manual transmission, try making a gearbox that will last with this motor... Bugatti had a team of 50 engineers working for 4-5years JUST on the transmission. F1 cars trannys only have to last 1 race.... Each car costs 5million pounds to build, and they sell for under 1million... bargain of the century.... You just can't compare the Veyron to anything else, not an Enzo, Mclaren.... specially not a GTR.
Well actually each car does not cost 5 million pounds to build, but if you divide the amount of money which was needed to create this car between all the Veyrons to be produced then yes, it will amount to 5 million per car.
IMO the veyron is a engineering feat, but if i had the money I would much rather buy something else...
Ditto.. there would be a big list of things I'd buy before one of these!
how does shut up sound?
if the whole car was smashed and only have of its engine was left, it would still be worth more than any of our cars and still pull better then most. if that doesnt get your respect then you need an egyptian sidekick the the head.
:happy:
wtf is an egyptian sidekick?
can you make my sidekick a chinese one? :happy:
i don't want to sound like a spoil sport, but a crashed veyron doesn't bother me in the slightest way for a couple of reasons:
1. in my opinion, the veyron is a try-hard attempt by bugatti to make the biggest and the best. quad turbo W16, what the hell for? the koeneggsig ccx weighs nearly half as much and probably has similiar performance as a result.
2. the veyron is far too clinical for my tastes. i look at a mclaren and i see passion, emotion. same with an enzo. i look at the veyron and i see white coats, calculators and pens.
3. how would you feel in a veyron when LEEWAH or GTR-800 pull up at the lights and actually manage to keep up? not very happy(unless you are in the GT-R! LOL)
is it sour grape season already?
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
