ok, got some info, see if this helps:
see pic;
DISPLAY AND NAVI
32 Reverse lamp
33 Parking brake
34 foot brake
35 inhibitor (something to do with auto ??)
25 speed meter
my guess is track down 33, which i guess is on the back of navi unit or radio, check if it is earthed when park brake on/off and cut/earth appropriately. the unit on the upper right of pic is the tv tuner in the back.
Thanks Chook, that's great!
I will get in and have a good look at the tuner and let you know how I get on.
Cheers
Luke
(You can read Japanese yeah?)
  • Replies 98
Ok, no luck at all with that wire chasing, seems like I have about half the amount of connections that the diagram shows so might be the wrong model or something... I will hunt through the manual and see if I can post up what my (wiring) setup is like.
Basically I have 2 looms running into the head and only one of these effects the screen switching and that is not the same one that supplies the video feed from the tuner in the back so I am looking at a maximum of 12 - 15 wires for a solution. None of the wires are doing a simple earth or power switch though so I may need to be looking else where for some form of switching unit that is sending a more complex signal to the head, nothing seems simple electronically with this car...
Cheers
Luke
Ok, appears more complicated than i thought too, operates on both the Auto and handbrake. here is a pic of the screen overide unit, which jumpers in between the white plug and the back of screen, as you can see, it is quite complicated, about 10 wires going into it. the small black plug is for a dash switch to operate the overide. Ill check Jap websites to see if this is still available, but as for doing it yourself, It looks pretty complicated after seeing this harness.
http://item.rakuten.co.jp/rca/datasystem-ntv142/
http://www.rakuten.co.jp/kong/645758/646238/645808/
NTV142 is the one you need i believe
Edited by chook
Awesome thanks, think I need to look at this approach.
(sorry I have been PMing you and not looking at the topic!)
Don't forget that not all ECU's etc use a Positive voltage to signify a signal on/off
for instance on some ECUs pulling a wire to ground makes stuff come on ( ie thermo fans )
so perhaps look at that if you dont have any luck
* sorry I know thats not at all directly related to your problem so it may or may not help *
Converter box is in and working 100%, very easy plug and play unit and after seeing the complexity of it and how many of the wires in the loom it effects I don't think anyone would be bothered to work out how to achieve this without it!
Unit is the same as the one Chook has posted the image of and a huge thanks to him for his help with this, would never have resolved it otherwise.
Rear view on the screen while driving is pretty cool (easily amused)
Now I am considering multiple cameras and a switch box...
Cheers
Luke
I got a friend in Japan to order and send it for $200.
Ahh! So does this actually convert NTSC to PAL (ie; get the DVD, TV etc. working) or is it something just to get a camera going? Sorry if im asking a question thats already been answered, i didnt quite catch on from the previous posts ......
No, no converting at all, this is all just about having a video signal on the factory screen while in motion.
I get ya now :P
So there is nothing available at all to get the factory TV etc working besides changing the unit? Reason im asking this is because i dont think i can actually change mine (its got the air con etc.. all in the one unit) so yeh, just wanted to know basically what will and wont work :(
I get ya now :P
There is a converter available that converts PAL signal to NTSC format or vice versa. Google it.
http://www.threedoubleyou.com/cdm660.htm
I run this NTSC converter along with a 12V digital STB, plumbed into the VTR2 inputs, wired into the factory window aerial, quite an effort, but well worth it.
  • 1 month later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
