pretty stupid thread but don't know where else to ask.
drove past a very nice mercedes benz this arvo but didn't get a look at the badge on the rear.
its a 2-door and both rear quarter windows can be opened aswell. size wise it looked as big as a soarer. had big square headlights and squarish taillights aswell. dropped on big amg rims it looked nice as :(
anyone know what model merc i'm talking about? i think i'm in love :(
praying to god its one of the cheaper model mercs :( .......bah there are no cheap mercs :rofl:
EDIT: oops thought this was the general section :)
Edited by R-SPEC
https://www.sau.com.au/forums/topic/159406-what-merc-is-this/
anyone know what model merc i'm talking about? i think i'm in love :)
praying to god its one of the cheaper model mercs :( .......bah there are no cheap mercs :(
EDIT: oops thought this was the general section :(
What year you talking about> Sounds something like a 560sec google em see if its what ya talking about. Big two doors 5.6lt v8 rear windows can go down etc. :rofl:
only ones i can think of off the top of my head that are as big as a soarer and have old square lights and are newer then the old 560SECs are the 320CE, CLK (altho thats probably no where near the length of a soarer) and SL500 Hard top (which is one of my favourites)
woot! 320CE :sorcerer:
could only find a topless version pics on google but that's the one :P
just carsales.com'ed it.....its too expensive :laugh: back to japs it is :laugh:
always loved the 500sl one of my favourite cars ever. :rofl:
cheers
The car you are talking about is a CL - the 2-door S-Class.
One of these:
Drug dealing at it's finest.
If you're the big dick on the block - you drive the CL63 AMG.
If you're his boss, you drive the Brabus version.
Clicky - http://stadium.weblogsinc.com/autoblog/hir.../brabuscl02.jpg
MY GOD!!! the black 1 (far right) :O
:P:):D:wub:
thats the 320ce yea? definately going on the list of the "must buy cars" ;)
personally that's one of the best looking cars i ever seen. and all they need is some nice big rims and lowering/bags :wub:
Edited by R-SPEC
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
