I use the Alcon kit, 6 front 4 rear, braking performance was improved immensly, still using standard master cylinder and brake booster...
My car is a street car aswell as a track car, don't see the point in changing anything else brake related. e.g pedal box, twin masters etc... I am definetly interested in trying different pads though...Using DS3000's at the moment...
Oh, and I have the Nismo brake ducts aswell for better cooling....
There are another 6 or so modified GTR's here in Vic that run the bigger brake setups and they too haven't changed boosters and master cylinders either....
  • Replies 75
Posted Images
cheers mate that info is much needed. im lookin at ap and grec systems aswell same size so i think they all will work the same do all the guys run alcon or do some have ap and grex????????
I use the Alcon kit, 6 front 4 rear, braking performance was improved immensly...
I dont doubt they are working better then your old setup, as i have heard similar comments from ppl who have moved away from the F40/50 Brembos.
But when you say immensely, how do you measure it. My thoughts from what i have read and the very limited experience actually driving a few cars is the feel. That changes greatly. I have never driven one long enough or hard enough to feel the improived consistancy...but i think even looking at things on paper its a given they work more consistantly.
But does the car stop any quicker, and if so what sort of improvement? Can you honestly equate an improvement in lap time to the brake upgrade?
One of the guys runs the full AP setup, another the same Alcon kit as me and a few with the Harrop full setup.
There's no one running the G-REX setup that I know of, so can't comment on them...
My F50 setup was definetly much better than standard, although I was running standard rears that had not been touched since I bought it, and upon removing them, the rotors and pads were quite worn. So I guess with new rotors on the rear with decent pads, new rotors on the front and maybe a seal kit through the F50 calipers the setup might have been just as good as the Alcon kit I have now, but the availabilty of the Brembo F50 rotors and the money to freshen up the rear gave me the incentive to bite the bullet and get the Alcon kit..
I did not measure the braking performance by distance or lap times, but it felt much stronger under brakes, I guess new rotors/calipers/pads and great balance does that. I cannot compare lap times due to the fact my car has undergone more mods since the new Alcon kit went on the car, aswell as myself improving driver ability.. :)
Well good luck getting service out of PWR for the Alcon gear. Maybe it was just me or my timing or something but I wasn't impressed by their lack of response or their prices. Racebrakes on the other hand couldn't have been more helpful (AP Racing)
I can't comment as I've never dealt with them myself, but a guy on the LS1 forums has been dealing with them and it seems that they are quite helpful. He's flying up there to trial there kits before he makes a decision, maybe you should contemplate doing that danoz? Try before you buy :)
1. A long brake pedal (excessive motion)
This can & will happen if the new calipers you choose have too great a piston area. Remember bigger is not necessarily better.
2. A heavy brake pedal (excessive force required)
This is actually fairly difficult to achieve with the Nissan setups, but if you try hard enough...
3. An imbalance in the front to rear braking distribution (premature front or rear brake lock up)
An imbalance can quite easily occur. You need to carefully match the rotor diameters, piston areas, brake master cylinder to all work in harmony. If for example you end up with big front rotor with a small piston area you are pretty much guaranteed to prematurely lock fronts & actually degrade the overall braking performance. That is why you need to talk to the vendor & confirm that your chosen set up has been successful on someone elses car.
The things people need to measure are the following:
Longitudinal retardation.
Brake temperatures.
Rotor & pad life.
Obviously there are other subjective "feel" parameters but as often as not this is a function of the rotor & pad as much as anything.
With regard to my R32 R. It has standard brakes.
The maximum gees I can reach under braking is a little over 1. About 1.1.
The rears do lock before the fronts, but there isn't really enough braking power to lock the fronts from high speed with R compounds.
The three thermographic paint markers on the rotors have all flashed off & the rotors themselves show signs of surface cracking which is how you recognise a rotor that is working hard.
The rotor life sucks, but the DS2500 last well.
Yes I need better rotor cooling.
As an aside if anyone has the specs for the 4 pot Alcon gear, ie piston sizes, pad sizes, caliper weight/dimensions etc I would be interested in finding out what they are.
As another aside here is a cutout of the AP Racing CP5555 caliper & rotor failing to fit inside my 17" rims. (Previous post)
Edited by djr81
Someone is about to trial some R32 GTR calipers on 340mm rotors. I was going to do it, but honestly im sick of wasting money trilaling stuff because im curious...my car is still slow. Any money i spend from now on has to make my car go quicker ;)
yep, it's me. going to try for 340mm 2 piece rotor, standard GTR sumitomo caliper. I have already done about all I can to optimise what is there:
braided lines
master brace
good fluid
tried heaps of pads
DBA 4000 rotors all round
cut off the backing plates
the only think left I can think of is trying this bigger rotor, and also some ducting. I need to get my hands on some R32 GTR standard brake ducts as sadly mine were absent when I got the car. but I think with all the gear I have, and the 340mm rotor and some ducting the car should stop quite well for at least 4 or 5 laps. and hopefully the 340s + stock caliper will just fit under a 17inch rim (which is what I want to run).
Yeah, we now use exactly the same setup, even the DS3000's, and it is superb.
After initially hoping that F40/F50's would suffice, we were sadly made aware that half way through one 6 day event, the genuine Brembo 2 piece rotors had several radial cracks and we were forced to "cruise", well, at least back off to 7 tenths anyway. ;)
That was a bad enough experience to bite the bullet and get the Alcon's through PWR, and they were on the doorstep within a week, and were quite simple to fit.
Pedal feel is excellent (on the std master to my suprise), and balance seems quite good too judging by the wear and feel of the car. Pad knock-off however is more noticable due to the larger rotor diameter, though we may minimise that by tightening/replacing wheel bearings.
thanks heaps guys is seems to be the guys with the bigger brakes love them and the guys that dont have them bag them and say there not worth it. i have settled on 6pot fronts with 355mm rotors 4pot rears 330mm rotors with ds2500 pads for street and montly track work
I agree with what you are saying Mad082. But thats not indicative of the whole truth. Driving a car fast is very much a confidence thing. So whilst the std setup is good, and the stopping distances are very dependent on tyres. Improving the feel and comfort of the driver is a big thing. Especially on tarmac rallies where concentration must be maintained. Worrying about how the brakes are feeling/performing is something you can do without.
So the feel you get from the more rigid calipers, larger rotors and improvements in consistancy is worth a lot. Even if physically the stopping distance is only 8mtrs better. But then again in tarmac style events often the difference between midfield and top of the field is less then 1/10 of a second per km.
So, looking at a thing like being able to lock brakes in isolation is neglecting so many other aspects of driving a car quickly.
After initially hoping that F40/F50's would suffice, we were sadly made aware that half way through one 6 day event, the genuine Brembo 2 piece rotors had several radial cracks and we were forced to "cruise", well, at least back off to 7 tenths anyway. :)
What size rotor are you running under your R34 GTR rims?
I'm running the AP 6 pot CP5555's with 375mm rotors with the standard rear brake set-up.
I haven't altered anything else other than braided lines and a master cylinder stopper.
I'm very happy with the set-up as I found the original configuration to cause me to trail brake a little too much where as for me this set-up has balanced the car out under heavy braking.
365 front and 335 rear. They're close, (and do get a few graunchy noises with rocks between the rim and caliper), but man they work well. :P
Thats good to know that 365 with alcons fit under the R34 GTR rims...
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
