Hi all,
Just found out today that the Air con is not really working properly. Here is the history:
Last year, after I bought the car, found out that it was not gassed. So took it back and got it gassed. Almost exactly a year later, the aircon is gone. Is it possible that re-gassing only lasts for a year?
When i turn it on, it makes some sound as if the aircon is working, the engine idle is still the same or just a bit more, and the fan works harder.
Im guessing that once its re-gassed it should last for a while. So maybe there is a problem with the aircon unit???
If possible, does anyone know of a place where I can take it for it to be checked out around the Mt Waverley/Glen Waverley area?
https://www.sau.com.au/forums/topic/159640-air-conditioner/
Probably a leak. Apparently the A/C people can use some kind of light to see the leak. Might just be one of the fitting on the pipe, or your release valve might be loose.
Either way, give your local A/C place a call and ask them rough figures. =-]
https://www.sau.com.au/forums/topic/159640-air-conditioner/#findComment-2964756
one of the reasons it leaks is the r134a that is used. It isnt suited to the jap aircon systems. The way ive heard it was the gas particles are minute compared to the origional r12 that was used, so any potential leaks are more likely to leak...
The way to get around this is to use r12a which is more similar to r12 that was origionally used.
https://www.sau.com.au/forums/topic/159640-air-conditioner/#findComment-2967928
No the drop in replacement for R12 is R49 iso. Or 409 which is not really a car gas but can still be used just as well. The problem with converting to 134a is not the particles its the fact it eats the rubber o rings out, due to different make ups.
https://www.sau.com.au/forums/topic/159640-air-conditioner/#findComment-2974549
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
