My mate actually had something similar in his 260Z.... was a LCD set up controlled in cabin... could change the plates to any combination you wanted in a second..... hence to say he had the setup imported, got away with it for quite a few years then got caught and slapped with over 8 grand in fines etc...loss of license for 3 years.... Stupid thing was after he went to court etc .... the police handed them back to him :P
Lol i was reading some replies to the video that said exactly that. Huge fines if caught also the bull run stickers on a gallardo you don't really need plates to be recognised
there is also a product in the states which covers the plates with a highly reflective chemical which bounces the flash from camera and doesn't show the plates in the photo. The chemical itself is invisible to humans. Apparently things like hair spray can have same effect, but not quite as good.
Lol... yeah the whole sticker thing kinda defeats the purpose!
lol.... I remember putting hairspray over our plates years ago when we were 17/18.... never knew if it worked or not though :P
you do realise, all they have to do is increase the contrast on the photos and they'd own your ass
Hair spray and all that crap doesnt work, not sure about what the OP's vid is using.
Mythbusters did a special on speed cameras in S5 S4 - Speed Cameras.
The only way the could avoid a ticket was..
Even the lambo didnt beat the camera lol
actually there is a stuff that wokrs, have been using it for years on my bikes and cars, it's a specailty thing from the US. It is only found in FEW Specialty stores. It has 3d prisim glass particles in it, you can feel the in the paint. When you spray it on, these seam to line up somehow while the paint dries and is fine, looks ok when dry, possibly a bit dull and not as reflective.
BUT when a flash hits the paint, it goes bazerk, you simply can not read the plate. I have not had a fine ever. I wish i had a pic of teh bike with the phot of teh plates.
UNFORTUNATLY, the bike is recently sold, and the car has new plates, so i need some more.
it's that translucent electric glass stuff
not bad..
yeah, it's like the rear view mirror in my soarer which is some kind of LCD. at the touch of a button it goes dark electrically. same kind of effect actually.
Another idea is to use the material in welding helmets that goes dark when a flash hits it. I tried this myself by placing a newspaper behind the window and then taking a flash picture. The material reacts fast enough that you cannot read what's behind the glass. Downsides are:
* I haven't seen these panels large enough to cover a plate
* Only works if the camera flashes (i.e. night)
There is a guy in the u.s. that has a site and makes them but he is slow at producing apparently accrding to his site. On the upside he makes them for australian plates too. obviously for those who want something cool at autosalon right guys? right? cough*
The only place i can see myself using this is on my commonwhore not paying for the lane cove tunnell. Theres my political statement
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
