G'day Cliff, welcome to SAU.
It is as safe as anywhere else (eBay etc.). There are trader ratings same as eBay feedback and some guys have a straigh shooters list in their sig for deals they have done that went well.
I've only had one annoying deal (in nearly 50 over 3 years), and it was because Aus Post stuffed up.
If you use registered post you know the goods were mailed. If you don't use registered post (heck it's only $2.50) then you are rolling the dice. 99% of the guys and girls here are excellent value and will take good care of their skyline brethren. If you're not sure, pay higher prices from a store. Simple as that! :D
Oh yeah, dude you'll have an easier time here if you spell words properly. The SMS type is really annoying and people will generally ignore your posts when u type sumfin lik dis.
Cheers!
Mark
yeah thanks guys so all is safe hey. yeah as safe as ebay,
yeah i shop on ebay all the time so should be all good hear then.
yeh always registered post. thats the way to go.and then wat do you do if you find out that they never posted the item??
hopefully all goes well.
Pretty good as long as you keep your wits about you (like most places)
The car I bought off here was advertised as having 220rwkw and ended up having around 160 with a bit of extra tuning (started at 145), but most everything else about it has been good like he said (great condition, reliable etc)
I think I just happen to be a sucker :blink:
bought a fair bit of stuff of here before and sold a bit too, before trader tags were on, never had a problem, just need to sus the person out get all the facts check their history of post if you want, or organise COD.
Look at their trader rating and comments. Check if they are actually SAU members or long time forum members [not that others are bad, just unknown]. I've had no problems and hopefully haven't given any. If I ever did I'd give back the money for the goods straight away.
PS Don't trust them Mods though, they are all very suss???? No just kidding, Moderators are an excellent example of who you could trust [this was a paid comment]..........lol
I've bought and sold on here for a while and have had good experiences so far. Few tips:
1. Try and buy local if you can so you can pick up and inspect b4 you hand cash over
2. Failing that if you need to purchase from interstate, check the users background, things like how long have they been a member, trader ratings, check out their posts under user options, see if they are good mates with longstanding members or have attended public meets etc...
3. Phone the seller, ask questions, possibly chat via msn as well so you get a feel whether the buyer is genuine or not
4. Ask for pics
5. Be wary of newbies that have signed up the same day with 1 post to their name trying to flog cheap parts off
6. Rely on your gut instinct, if its too good to be true it normally is.
I actually had a really good experience few weeks back, actually persuaded the seller to send me the items before payment was made due to suspect circumstances. All worked out well in the end :wave:
GL!
I live in a backwards redneck town and the aftermarket parts shops and car yards we have are way over priced, so really I have no choice but to buy off the internet. This is a very trust worthy forum and I have personally bought and sold heaps of stuff off of hear no probs. However there are totally shyte forums that I'd never trust ie. Boost cruising, NS.com
I've bought two gearknobs from SAU group buys. One gearknob never showed up - probably Australia Post's fault but the guy who organised the group buy failed to ensure the items were correctly posted on two occasions. The other gearknob was faulty and this wasn't mentioned in the original description. I ended up getting the gearknob from Greenline. 3rd time lucky. Haven't bought anything else from SAU but that doesn't mean I won't.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
