hi,
Since it was designed for r33 (not neo) and since neo head has slightly different intake ports and AAC valve bolt pattern -- sure it will require more work to install it to neo engine.
But there is nothing impossible.
I love how everyone who has it fitted wont explain what was necessary to make it fit. This is a forum where people share information, so share, please.
Agreed.
Its the same people saying it "can" be done, or they "have" done it. But wont go as far to to share how it was done
OK it is bolt on;
just use a set of fuel rail spacers or R33 GTS-t rail kit, a R33 throttle body and greddy adapter or even better use an infinity item like in my pics. Very simple :dry: no black magic :P just a bit of re-looming to keep it all factory neat.
Edited by URAS
Standard R34NEO injectors I see... that's weird; general concensus a while back was that R33GTST injectors would be needed (top v side feed)
This is interesting; has dispelled a LOT of myths.
My question is this though; you say to use a R33 TB or other one... won't this remove a few components of the R34 since the NEO TB has a massive donk out the front which controls a few things?
Interesting work; well done!
OK it is bolt on;
just use a set of fuel rail spacers or GTR rail kit, a R33 throttle body and greddy adapter or even better use an infinity item like in my pics. Very simple :D no black magic :P just a bit of re-looming to keep it all factory neat.
Very interesting, some questions;
What o’rings/spacers/adaptors are used to fit the R34GTT (top feed) injectors to the R33GTST (side feed) manifold?
Why can’t you use the R34GTT throttle body? The throttle butterfly is the same ID, is it the bolt spacing that’s different? Possible to use/make an adaptor?
What throttle cable is used?
:dry: cheers :huh:
  • 7 months later...
i know its a old post
but trying to do this atm, i got some R33 Fuel rail spacers, but it doesnt seem a tight fit as it should be? did you use anything else? or there something you can do to make it tight?
also need a R33 ACC valve, as 34 one is bigger
Cheers
Justin
forgot to mention you lose traction control (a given since the TB controls it).... i hate it anyway :D
finished one with trac control still working for those that want to keep it.... piping is a nightmare though.
Cheers
Justin
in rail or in the manifold?
in manifold, fuel rail is all good, real tight fit. But put the 33 spacers in the manifold and then injectors into the spacers and isnt tight at all unless only pushed in a little bit and its sort of tight, but not like pushing into the stock manifold.
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
