Hi every one im Bianca
Just bought myself a white 33 gtst today after selling my wrx
loving her so far, mods are listed in my signature
just moved to brissy at the stat of the year with my partner (sinistagtst lol) so dont know many people up here yet so if you see a white 33 with the plates 828 klm with a little blonde behind the wheel give me a wave lol
this is my new beast
we stopped for petrol and de-riced 20mins down the road with the coppers pulled up next to me going :down: while they were filling up...no more ghey stickers for me lol
Edited by miss_sinista
Hello Everyone!!!
My name is Richie , i am new to this site and live on the Gold coast.
I own a R32 GTR and a VL 26/30
Hope to catch up with some of you guys on the cruise days. :)
Edited by richie$$$rich
  • 3 weeks later...
hi im jay, i own "GOT04" r33
its mainly built for QR sprints but still driven on the road a few times a month, seem to become less and less these days as i get more serious... lol
ive basicly touch every area of the car but theres plenty more to go
for a feature of the car click here-
http://www.clubhighrollers.com/forums/inde...?showtopic=1527
look our for it in HPI mag in a few months and its got a feature on tunerzine.com also
stay safe, wave if u see me
Edited by flyline
Hi guys- Mitch from the gold coast
Picked up a S2 stagea with R34 front end conversion as my daily- RB25DET, AWD and the convienience of a wagon:
And my weekend toy is an Evo 6RS:
Hope to meet some of you on a cruise or @ the track :blink:
