  • 3 weeks later...
cheers mate
We've actually been holding dinners each week for the past 4 weeks to try and gather more input from members as to what they would like. Whether it be track days, cruises, happy laps or piss ups. Next year will be a good year with what seems to be a lot of plans coming together. You should come to the xmas party this weekend and meet some of the boys. We also congregate on www.sauqld.com and discuss things there as well.
  • 4 weeks later...
Hi I'm new to the scene :) I live in Ipswich, work in Brisbane as an AV/IT Tech. I just purchased an r33 s2 gts-t , pretty standard mods, fmic, coilovers, ebc, high flow running 13psi . I commute in it daily up the western freeway carpark to milton so I might see a few of you around!
  • 4 weeks later...
Hi guys, just joined the forums and doing the rounds introducing myself. Purchased a 94 R33 GTSt in April 2012 in celebration of going onto my o3o end licence have not regretted my decision. Big step up from a 150hp FWD U13 bluebird XD. Hope to see some of you around. If you see me out and about feel free to say hi.
Hey ppls. Just joined up.
Car: R33 GTST
My Baby! Without the Wing on it.
Looking forward to meeting more skyline owners and hopefully go on a cruise with some of yas. :)
Edited by Deuscore
Car: R33 GTST
Hey mate loving the orange (I may have some competition for "most eye piercing colour combo" in Toowoomba now :P)
jump over into the Toowoomba thread and say hi usually Chris Tom Clint 180Nick or myself are floating around in there somewhere.... U just missed our last cruise/pub lunch but we try and do stuff as often as we can, hopefully we'll see you at one in the not to distant future :thumbsup:
*if you see some dingbat give you a wave from a red charade that'll be me :)
Edit: hold up I've seen that car before along James/west steet usually runs a big drift wing, themoreyouknow lol
Edited by Captain Natro
Cheers for the warm welcome bud. :) Look forward to chatting with you more soon.
Yep that wing is sitting in the shed at the moment, chews a lot of fuel. :(
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
