One Word Association Thread!
By welshy_32ZILA · Posted
Hi All, I have my BW EFR 8474 with a T4 split 1.05 rear housing. Rear housing is ceramic coated and drilled and tapped for EMAP take off. Supported 520awkw at 35psi through the 8HP with ~5k rpm spare on the BW 127k limit. Ran a 9.98. Turbo is one of the first that was released but only done ~3k kms. Asking $2800 happy to negotiate. Only selling to upgrade. Located Gladstone QLD happy to ship. -
Just wondering how come the hood was grinded down?
I have no hard data to report, but I have to say, having driven it to work and back all week, mostly on wet roads (and therefore mostly not able to contemplate anything too outrageous anywhere)..... it is real good. I turned the boost controller on, with duty cycle set to 10% (which may not be enough to actually increase the boost), and the start boost set to 15 psi. That should keep the gate unpressurised until at least 15 psi. And rolling at 80 in 5th, which is <2k rpm, going to WOT sees the MAP go +ve even before it crosses 2k and it has >5 psi by the time it hits 90 km/h. That's still <<2.5k rpm, so I think it's actually doing really well. Because of all the not-quite-ideal things that have been in place since the turbo first went on, it felt laggy. It's actually not. The response appears to be as good as you could hope for with a highflow.
Or just put in a 1JZ, and sell me the NEO head 😎
