just wanting to know what the consequences are when a p-plater is caught driving a turbocharged car when it is prohibited.
How much are the fines?
How long are suspensions?
What happens to the car?
also hearing a lot about ppl getting exemptions from the rta. is there any way of getting an exemption for a r34 gt-t standard?
cheers!
https://www.sau.com.au/forums/topic/161168-p-plater-driving-turbo/
  • Replies 64
- you'll get fined fairly heavily
- lose 3 points
- and get the car taken from you after a couple fines
you sure dats not da nsw fine's?
I perscribe Harden the fark up......If you have the balls to drive it on your P's then have the balls to cop the concequences.
+1 for :blush: Harden the fark up
Edited by Dan_J
A mate of mine got pulled over twice in one night by the same copper 2 weeks ago. heres what he copped twice, 7 points each time and $350 that equals 14 points in one night on green P plates in Sydney... Driving a close to standard R33 gtst he is spewin..We thought it was only 2 points each time lol
In NSW it is 7 points and a $384 fine.
You could try for an exemption but you need a really good reason to drive that car. i.e. If it was a ute or something you could say you need to drive it for work.
I can't think of any reason why you'd need a GT-T.
Good point...
lolz...too late..already bought the GT-T
jus couldnt say no to turbo
i only have till 19th april till i get my green p's and gonna apply for an exemption
if anyone here know a way of getting an exemption that would be great
cheers!
All three will happen
- lose 3 points
Really not worth it anymore. Just go and buy that 88 Laser you had your eye on
maybe the laws have jsut changed but all i ever get is a $113 fine and dats it.....dunno wat ur on about with the point loss and losing th car after fines, maybe its something new
cheers!
dumbest thing i've ever heard someone do. zero sympathy from here if u get caught.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
