Need some advice,
I have a Emanage Ultimate with a N-4 harness to suit R33 GTR.
I’m hoping to install this in my 1995 R33 GTR-V (standard)
Now after reading the instructions I am a little confused with this N-4 plug & play harness and the splicing of the Maf wiring ?
If my understanding is correct, even though it is a plug & play harness I need to carry out some wiring mods.
Can anyone clear this up for me, or point me in the right direction ?
Cheers
Kerry
  • Replies 765
I think its direct plug&play. No need to change anything if u got r33 gtr harness and have r33 gtr car )) If u got gts-t, u have to swap a couple of wires around.
Edited by robots
Thanks for the reply,
I have plugged the unit in and it runs, all be it very rich.
I'm getting a Maf2 not detected fault. Looking at the wiring it would appear that both Maf signals join into one feed for the standard comp?, but may need splitting for Emanage?
No one else has done this on a GTR? Great love been the first. Hahahahaha
Hey, do u run the latest firmware ? My emu on rb20det was also running rich in standard. I was playing around with inj. options and got it to idle with good afrs, but than I had some fuel cut on high load. In the end, 2.16 firmware fixed that. Still got to sort out some stuff, but it runs decent now.
http://www.mohdparts.com/emanage/pc/ultima..._Vmanage109.exe
Hope it helps.
Think it running 2.13, will have to check that.
The Maf2 or can no detect Maf2 fault is the one I can't find any info on.
Will keep play with it, I'm sure with some hacking it will come good.
Cheers, he must be busy at the moment.
As I sent him a Pm last week.
I'm away at work at the moment, But hope to do a little bit of good old trial and error with this when I get home.
If nothing else comes up.
Cheers
Cheers
Sorry been in hk, china and japan til tonight.
If your std comp has both wires joined at the ecu (i think i read that above) there must be an issue somewhere in the car. The front cut i got to use in cats car was the same... it turned out it was mapped to run them this way.
i would join on the emanage harness both maf wires so it sees the same signal the ecu was before.. should fix your maf signal fault.
i would also look to see WHY they are spliced at the ecu just in case there is something that may bite your ass later on down the track.
What I've noticed is that Greddy have changed the RB20 inj. lag time in the latest update(2.16). It was 0.70ms before, which I think is right. And now its 0.
still confused ))
tis a funny thing this latency adjustment, uchida-san has told me to use 0 in both fields if using std injectors and to chance it only when upgrading.... but some older EMU prefer to have some adj in there.. i have played with a few settings and got good results so tryinputing a few values between 0-0.7 and see where it runs best at. It always works fine with larger injectors i found.
It is a very rare issue but i have come accross it. Usually updating the EMU fixes it.
Hmmm.I have the latest firmware(That came with 2.16 software), then I got the 9xxx series ultimate, version E.
I still have some kind of fuel cut around 140-150km/h in 3rd/4th/5th gear.
When playing with inj. latency, should I adjust both values?(old and new) or just the new inj latency value ?
Thanks, Trent !
yeah I changed my latency to 0 and it ran like shit
Found that on .7ms it runs way better
it must be a trial and error sort of thing
I connected an LC-1 to my car last night so I shall see what effect it has on my car
Hey all,
I tried starting my RB20 the other night for the first time with the ultimate.
It has a map loaded on it for 550cc injectors, z32 afm so I can just get the car started.
I have spark and the fuel pump runs when I manually spin the CAS, but no injectors firing. Any ideas?
Could there be a problem with the settings (possibly latency) with the injectors, or perhaps the map has wiped itself? I need to get a lap top onto it to have a snoop, but until then any suggestions on what to look out for would be helpful.
Also, the car starts fine without the emanage.
Cheers
-Jez
Hey all,
Cheers
-Jez
hey i finish my course on wed night i can come round any day after that... name a time i'll bring some jb's and we will get it sorted. is it ready other than that for tuning ? maybe kill two birds with one stone?
Dont worry about ACSPLIT he is still cut he drives his mums car :ermm:
Dont worry about ACSPLIT he is still cut he drives his mums car :P
Hey man,
I'll give you a call tonight or tomorrow and organise a time. :D
I'd love to kill two birds but I still need to put the clutch in and get my front wheels back from being widened LOL....and it would look weird tuning a car that is just a shell and in primer P
LOL @ AC, I remember three years ago it was all WOLF3D for you...... nah, just teasin ;)
I've did some more runs yesterday. Tried different inj. lag time. If I remember correctly this time I've used 0.15ms lag time, compared to the greddy default 0.00ms lag time. I tried everything from 0.55 to 0.15.But it was running rich on idle. So I just went lower.
It seems like a fuel cut or something but only in the higher gears.
Like if I accelerate hard in 2nd, 3rd, 4th I just hit the factory 180km/h speed limiter. While accelerating in the higher rpms I can feel I got some missfires. Like small pops from exhaust. Very annoying.
If I start accelerating hard in 4th gear I just bump into this fuel cut around 160km/h. In higher rpms I also have this fuel drop outs. You can see them in datalog very clearly. Inj. input duration just cuts out and comes in again.
In 5th gear I just hit that fuel cut earlier like 140-150m/h. And syou still get this misfires while revving.
I just don't understand why is it happening ?
Any ideas ?
Thanks!
EMU_Test_Drive_datalog_30.01.2008.zip
Edited by robots
for starters the speed cut should be disabled.... it is in the settings manual. I will look over you log later today once i pick up my lappy.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
