  • Replies 72
Hey mate how ya going?
is your car a series 1 or 2? casue im after the AFM for a series 2 desperetly so if you got one can you let me know how much it is?
Cheers,
Traum
Hey Mate,
Empty your mailbox, is full, no PM's can be sent to you. I am after the STOP light glued to the windscreen (rear). Is it in good condition? If yes, how much?
Cheers,
EUG.
Hey I'm after the drivers side front inner gaurd lining. You know the plastic sheet thing that is between the tyre and the inside of the wheel arch. let me know if you have it cos i will definately buy it off you. cheers
hi,
reason for selling: i recently crashed my r33, its a shame to let it go like this but i'm selling it in parts.
Item location: melbourne
Items: rb25det engine - make an offer.
5speed gearbox - make an offer
brass button clutch - $350
oxygen sensor - $70
Crank angle sensor - $50
Stock airbox - $50
Stock ecu - $200
Seats - make an offer
Gtr Wing (painted black) - $200
Veilside side skirts (painted black) - $100
how much for carpet
momo steering wheel - $100
Basically the whole car is salvagable.. so if you need anythhing i'll have it. so just send an email... unfortunately i havent got any pics as yet.. i'm gonna take some in the next few days.
regards
  • 1 month later...
  • 2 months later...
hi,
oxygen sensor - $70
Stock airbox - $50
Stock ecu - $200
regards
hi will you take $900 for gear box ? pls let me know cheers can pick up asap
hey mate,
after the left rear seatbelt buckle, including the bit that bolts to the floor. also keen for the diff if its a 4.3 (auto).
get back to me or email me [email protected]
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
