quickest car i ever been in was a gtir. modded ofcourse.
similar to LTHLRB - a mate also owns one, did drive it hard and blew the box. been sitting in his garage for about 6 months now, not cheap to repair....
its one of those cars.....always loved em, but would never buy one.
they are not that weak. I ran mine with 180 odd 4wkw for a fair few years and I don't think anyone could suggest i didn't drive it hard. plenty of 7000rpm launches in it! BUT no flat changes, and a bit of mechanical sympathy is important. also short shifter is not a good idea, and the type of clutch you buy has an impact too. but i wouldn't say their boxes are fragile, it's just you need to be a little smart to keep them happy. apart from that they are good. they only weigh around 1200kg, can easily put out 2004wkw with standard turbo and injectors and at that power will dust off most mildly modded skylines. they do NEED a brake upgrade though as they come with shit brakes. top little car though, and a steal at current prices.
I owned one briefly.... but mine was a lemon..... previous owner dodged the maintenance records amongst other things.....
My mate had one also .... awesome car.. but it did have $40K spent on it at Rigolis!
In stock form I'd go the gtir over anything else in the same price bracket just because SR20 powah (and build quality) and the lack of money that needs spending to get it go faster..... although can be a b!tch to work on at times according to my dad (mechanic).....
GTIR drivetrain is a heap stronger than any wrx of the same year model.... our 97 wagon (clubspec) has done two gearboxes and the next time its straight cut gears! Also to me the wrx feels like its made of plastic.... but thats just personal opinion...
Fast little car,
If you ever buy one or import one, make sure it comes with exhaust already as its can be a bitch to fabricate a proper system. As for the clutch, if you need to change, get something that worth it as you would need to lift the engine up a bit and just chuck REDLINE shock proof in it and the box will be fine, offcourse don't abuse it too much.
What can i say about SR20, they are great 4cylinders, respond to mods as good as EVO if not better, engine and parts availability is much more as well. Oh also don't forget the quad throttles respond (was it quad throttles?).
Better interior than R32gtr :P, semi bucket seats, CUP HOLDERS ;).........
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
