Just want to know what figure the stock torque split gauge in the dash sits on when cruising at 90-110km/h in 5th gear.??
Mine is nearly on the second dash at 100km/h, i cant remember if this is normal or not, when i cruise at slower speeds say60-70 it sits on the bottom.
The torque transfer to the front wheels goes up heaps if the rear tyres are smaller diameter due to different size or wear, as the computer thinks that the different axle speeds are constant wheelspin, or you could just get one of the awd controllers, it cant be helping your fuel economy
at 100km/h i on the first dash , slower speed on the bottom
Mine sits on 0 at highway cruise (in fact, any-speed cruise). You probably have a reading because the rears and fronts aren't matched sizes and the ATTESSA computer thinks you have a bit of wheelspin. Try swapping the fronts and the rears and see what the gauge shows.
Same as blind_elk here champ. When I had smaller dia tyres on the rear it was a pulsing torque reading and through the pants feeling.. not just a constant reading.
Any error codes on your attessa ecu?
James.
My rear tyres are a different brand (but same size 235/45/17) to the front tyres and are a little worn, fronts are new.
I was wondering if it has anything to do with my new motor( rb30det) combo ive just put in the car, as before when i had the stock RB20 i dont remember the gauge reading that high.
How do you get fault codes from the attessa ecu, is it located under the parcel shelf?
The tyre size issue that i had was with 235/45/17's both ends, but new ones different brand on the front. Same as you seem to have. Just swap them front to back and see if there is a change.. easy. The difference old to new and different brand was enough to make mine go nuts.
Attessa codes are read from the module in the boot. There is an indicator led on the housing that you read codes off simillar to an engine ecu.
I have attached the ets diagnostics sheet, maybe that will help.
James.
ets_diagnostics_extract.pdf
Edited by heller44
So the rears are smaller rolling diameter, and causing the ATTESSA ECU to think that you have wheelspin. Also, just because the tyres are "the same size" doesn't necessarily mean they have the same rolling diameter.
Swap the fronts and rears and the gauge will behave itself.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
