  • Replies 181
haha nothin hotter than a done up GT-T,oh unless of course there is a hot girl in it. but even when they are stock they are hot! :) or a GTR R34. Your obviously gonna be there ze_flexy_1? and not jus for the cars :)
Edited by Darkness_Ryda1
haha nothin hotter than a done up GT-T,oh unless of course there is a hot girl in it. but even when they are stock they are hot! :) or a GTR R34. Your obviously gonna be there ze_flexy_1? and not jus for the cars ;)
Ahhm yeah ill be there for the ride.....aka If the boyfriends GTR is currently working and he wants to go.....shall see.
I should bring the just car undies....that seems to be a hot topic lately
