Flashing Airbag light
skyline33
 Share
My mate has a series II R33 and the airbag light keeps on flashing, all connections were checked and everything is fine. is there anyway apart from taking it to nissan to reset this fault.
I did a search and found this but i'm not sure which is the driver door switch:
THIS IS HOW TO RESET THE AIRBAG COMPUTER
First you have to put the system into the diagnostic mode. Here's how to do this:
From User Mode To Diagnosis Mode:
Diagnosis Mode activates only when a malfunction is detected, by pressing the driver's door switch at least 5 times within 7 seconds after turning the ignition "ON". SRS will not enter Diagnosis Mode if no malfunction is detected.
From Diagnosis Mode to User Mode:
After a malfunction is repaired, switch the ignition "OFF" for at least 1 second , then back "ON". Diagnosis Mode returns to User Mode. If switching Diagnosis Mode to User Mode is required while malfunction is being detected, switch the ignition "OFF", then back "ON" and press the driver's door switch at least 5 times within 7 seconds.
After a malfunction is repaired, return to User Mode from Diagnosis Mode by switching the ignition "OFF" for at least 1 second, then back "ON". At that time, the problem code is cleared
that happened to me once when I had the boost gauge put in airbag light went flashing whenever ignition was turned on, it happens when the car senses a voltage leak or something or other...but they finally cleared it all up and I believe it was with the instructions you got(they told me they got it from the internet too)
anyway, i believe the switch is the little black rubber button thingy on the drivers side door near where the sticker for the tyre specs should be, i saw him pressing it a number of times along with some other stuff he did.
 Share
    • Yeah, I get that. I try to be as cost-efficient as possible with cars, and typically prefer to buy them at the bottom of their depreciation curve. I was looking at those Bilsteins too as they're roughly in the same price bracket as the BC's - lack of adjustability and being soft put me off, not that I want anything too hard. That's my issue with the Skyline, it's too expensive and it's reflected in my driving. I don't mind going full pelt as long as there's a gravel trap to catch me. Really, proper safety equipment is needed for total confidence. Well this just turned up for the BMW. I'll try and get the front together tomorrow and take some pics of the absolutely horrid rear end; perhaps I'll have a crack at the rear on Wednesday. I need to make the car drivable before the weekend as I'll be driving it over to London.
    • Hi SAU community  Wondering what my 93 Very RARE TH1 Blue R32 GTR VSpec is worth these days?? Build is fairly dated now All Mods are Compliance Approved  Runs RB26 done only 10000ks Greddy T88 done only 8000ks HKS Cam 1000cc Injectors Full Titanium Exhaust Nismo Intercooler Nismo Oil Cooler HKS Oil sump Tein Super Street Coils Cusco Sway Bars RAYS TE37 19x10.5 DYNO street tune makes around 700hp on 98octane
    • It does sound like a fuse considering the indicators work..I’ll triple check when I’m free and report back.    thanks for the reply.
    • no, the car was a manual 5 speed from the factory and still is.
    • While going through data logs late last week, I spotted a small issue with my WMI. My WMI starts to progressively inject at 11psi of boost. I'm using a 25psi cut in pressure switch on my WMI as an added safety and if the curve is linear, I should hit that 25psi on my WMI system around 13-14psi of boost.  As per my data logs, my WMI pressure switch only activates around 19psi of boost. This is causing my non WMI 4D map to trim for WMI. I'm presuming this is caused by the mechanical switch response time, injection curve not being linear or both.  I ordered a 2-10psi adjustable cut in pressure switch which should correct this. If this doesn't resolve it before my dyno appointment on Friday, I'll just remove the pressure switch temporarily and more than likely replace it with a pressure transmitter afterwards.    BTW Speedtek has yet to refund me.
