hurro,
my bother was saying something about how the cameras on the ring rd don't snap you for going over the speed limit but they calculate something between between 2 or so cameras that you drive past then they work out whether you were speeding? :) :)
does anyone know what i'm talking about or where i can get some info on this?
is this old news? lol
thanks
  • Replies 42
The way I herd that it works, is that both cameras record your vehicle. Software matches the vehicles up (REGO) and calculates the time it took to for you to travel from A to B and works out your speed. There will also be the normal Fixed speed cameras and road patrols.
I think it's only the ones on the Hume HWY bypass that snap you over distance.
I'd imagine it would be too hard to do the same on the Ring Road, with the variable speed limit.
Off topic. But do you work on prospect st in box hill. I thought I saw your car there today.
R-SPEC: Yeah, my missus lives just off Lygon St, so it may have been a possibility it was my car.
Ray: The cameras that detect your speed point-to-point are on the Hume HWY.
The Ring Road cameras are:
Greensborough Bound:
Boundary Road - Behind the Signs
Western HWY - Behind the Signs and on the Exit aswell
Keilor Park Dve - Behind the overpass
Pascoe Vale Rd - Just before you get into the tunnel
Altona Bound:
Widford Rd Bridge - Behind the overpass
Calder Park Overpass - Hidden up high between the two bridges
Western HWY - Just before the exit, hidden behind signs
^^ No, having to have to do 20Ks or less on a freeway just coz you felt like speeding for a sec beforehand
thought so.
Edited by R-SPEC
I played a part in the setting up of these the new western ring road speed cameras. I told my boss when he gave me the job if I had a religion this would be against it. They are the old fasion if you speed you get your photo taken type. There is even a second camera linked to the system that takes a pic of the variable speed sign at the same time it snaps the speeding vehicle.
The Westy ring road has these cameras, saw them yesterday, also the temp signs saying 'Cameras are on, speed cameras reduce accidents' or something like that. Mind you i nearly side swiped a falcon wagon full of newborn babies reading it!
I had a thought ....... and Yes it hurt...... If you abide by the speed limit...... mabe ..just mabe.. you won't have to worry about getting booked?
That said .... i spend so much time looking at my speedo these days, that i rarely have a chance to see where i am driving.. so look out for all these responsible drivers doing the speed limit while running you into a concrete pylon.
are u serious that there are speed cameras that measure the time it took between the two and book you on that!! Where exactly for a fact are these cameras.
There is nothing new about this style of camera, these have been operating on the M1 in the UK for several years around the midlands area. They run over 3 sets and the idea has most likely been deployed in other areas by now as I remember when they were trialled. :)
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
