  • Replies 237
Posted Images
Thanks for the quick reply Roy covered everything there. Good to hear that a few of the SAU guys offer guidance on the day.
LOL...my type of guidance ..
"Ok your turn...now did you see my lines and braking points?"
"Yep"
"Well do the complete opposite and you will be fine, and quick" :whistling:
no way Sandown is scarier than PI!
am I a traitor for wanting to do the Maserati day there the week after instead? heaps less cars than the WRX days usually... I had 10+ laps in every session last time I went... bit pricier than the WRX days tho... hmmm
It's those damn walls that are so close @ sandown :whistling:
Do you seriously find you don't get enough laps in on WRX days? (just interested) as towards the afternoon they usually let you go out in any group you want since half the field has broken something or been pinged for noise or something ;)
last night was my first time at the sau anual meeting and i had a lot fun meeting every one and getting to know a few people out side of deca so i just wanna say thank you to every one for been such a great group of people and a great club to be involved with.
#ALSO I WILL BE DOING DRIVER TRAINING AT SANDOWN ON ANZAC DAY. :)
yeah WRX days I never seem to get more than a couple of clean laps in a row... Maser day I was flying around by myself until the brakes had melted! It helps heaps being able to do lots of back to back laps (in the same session as opposed to overall) and not have to wait around much in between... I can just push a tiny little bit harder every lap until I find the limit...
Sandown walls are scary but I don't look at them and the speeds and g loads through the corners are much less... PI I was just trying to grow some balls... trying to ease off the gas and just turn in instead of riding the brake coming up to the corner because I am not comfortable with just turning the wheel at 150km/h!
What's the hold up now Dane?
Dollar dollar bill y'all...
I've decided not to put the engine in until I get back from overseas, would rather amke sure I have enough spending money over there. The sleeving and all that is done, just not going to put the head on, or put it in the car for another few months. I'd rather wait and make sure it's all done properly than rush it.
My trip is looking more and more like being funded by a personal loan :blink: Car is good. so im going to drive it as much as possible. Hell, it jsut means i will have to sleep on benchs and beaches when OS, umm, actually ... :banana:
I will be sending my form off tomorrow (express post).
What do I regarding my competition number? It says enter preferred number on the entry form, but will they get back to me before the event with a number so that I have time to buy the appropriate stickers? And where can I get these numbers apart from revolution racegear?
Thanks (and sorry again for the newbie questions)
Yeh if you have race car with a permanent decal then they try to cater for that.
Also, updated first thread with those doing driver training and the guys you can to ride shotgun or have a steer to show you the lines.
if you need me i can help, but you'd be better off using the others first since this will be my first time at sandown...
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
