  • Replies 237
Posted Images
My trip is looking more and more like being funded by a personal loan :blink: Car is good. so im going to drive it as much as possible. Hell, it jsut means i will have to sleep on benchs and beaches when OS, umm, actually ... :D
*rubs new credit card*
Mine will be funded by the bank for a large part anyways, even without putting the engine back in :)
Benches and Beaches are your specialty Bris, shouldn't be a problem!
Who would believe that im looking forward to doing the oil change this weekend. All i need to do is new oil. filter, and flush the brakes. Im pumped. So looking forward to gettign out there are tryign to beat my 1:25. I thought it would take a few weekends to get my car to do a 1:52 at PI. The fact that i did it first go and easily has me hoping for big things. But anything under 1:25 would be good.
Just hope the weather is good. So pumped. Up for the Dawn Service then off to Sandown :D
yep it would!... have to find .75 of a second somewhere... think I might just have salad and water for the next week!
I reckon a speed limit defender or whatever they are called would help me with another couple of tenths on the straights... or maybe I'll wind up the boost, see how long that ceramic wheel lasts on 14 psi hehe
can I take out the passenger seat and still pass scrutineering?
Maybe later in the day. They will see how the day is progressing and if there seems to be time then they may allow a passenger session. Though as per PI you will only be permitted to drive at 75%, go too quick and the official wont be impressed.
Im probably taking out my passenger seat as well. :P Isnt there an easy way to disconnect the speed imiter in an R33. For sure rip the bastard out. The fact that you are going as fast as you are on the rubber you are with a speed limiter....absolute credit to you! :)
umm no. I've only taken my passenger seat out once, at Winton last year.
I swear I've seen it out at Sandown, but you'd know better!
Either way, you passed scrutineering like that, so it doesn't matter.
Nope never had it out at Sandown. I don't think it's a problem for scrutineering, why would it be?
Thanks Dane!
you don't of anywhere that might stock bits and pieces like speed limit defenders, strut braces etc... like an import wreckers or something... I was thinking JustJap but they are in Sydney and I want a few pieces before Wednesday... and Roy I'm too scared to do the dodgy wire cut, its supposed to mess with HICAS because it doesn't know how fast your going blah blah... I really need a power fc
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
