  • Replies 58
The spin around turn 2 was incredibly scary... Pretty sure I left some fruit in my loins... ;)
Can I still drive you car at lala sometime? :P RB30 power ahoy!
i'll get out there one day and u can show me how to drift (cars almost ready for grip, just need to get my diff in and oil cooler)! the three 32's looked good though in the team drift! ye that 31 did have them issues just like every other import 31 i know but he did a good job with the car he had!
Edited by mr_rbman
Yeah, we didn't do too bad, got 2nd. Behind team Peer, but they're amazing, so it was expected that we wouldn't win it...
Now quit ya yappin and get out there damn it! Circuit stuff too :P
Dodgy1_SA: Cheers for the pics man! Much appreciated ;)
Edited by salad
thats pretty damn good, the wheelworx boys weren't doin too bad either!
yeah what a dissapointing weekend for DCR, we had issues with the car all weekend.... somewhere in the 10yo factory GTR loom is an evil power robbing wiring gremlin.... car would not rev over 5000rpm consistantly.... bring on the next round.
i was suprised she qualified mid field with such a misbehaving car .....
It was a good show, I cant believe i made it down in such short notice but it was worth it :P
Well done Simon it was good to see you out there in the flesh and its only the start of more to come in the world of D.A
It was a good show, I cant believe i made it down in such short notice but it was worth it :D
:huh:
Thanks heaps for all your help man!
Got some awesome shots coming too, and some vids
yeah Easto has plenty of talant but seriously his car is way too slow in the grip department, it just squats and bags the rears, no real corner speed.
Wish i had me an RB30 package :P
was talkin to easto late on sunday, the talk is for retro-fitting an R33 diff and cradle under the back of the Black Pearl :P
smokeshow aplenty from the 31 brigade (and in SLY's case, Bee*R limiter abuse aplenty)
Got a whole heap of video and 200 pics to upload now that i hav my computer back
If anyone's interested, here are some other people's pics from the weekend taken from NS.com including an article about the weekend.
Article
http://www.speedshots.com.au/gallery/drift...ftaustralia_r2/
http://www.pbase.com/mcphotographics/070414
Edited by salad
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
