I finally got all my parts needed to do the rebuild. All parts are supplied by me.
Wiseco 40thou pistons + rings
Eagle H beam rods + rod bolts
ACL big end + main bearings
1.2mm HKS headgasket
Tomei Poncams
Heavy duty valves
Headstuds
N1 oil + water pumps
HkS timing belt
What workshop do you guys reccommend to do the job properly? Everyone seems to think that the only workshop in perth is Xspeed..Interested in feedback and experinces from other places. Any ideal or ball park is to how much much it will cost? I want maximium reliablilty and it all crack and pressure tested, x-rayed and complete bottom end balanced.
https://www.sau.com.au/forums/topic/164605-r34-neo-full-engine-rebuild/
  • Replies 44
well basicly because they build high horsepower engines that last... whats the point on spending $20000 to see it last 4 months, mines been goin strong for 18 months and not missed one tick.... they let their engines do the talking for them.... give john a call, mad not to..
you might as well just look at the consolidated workshop thread once again
seriously this thread will go no where we have all got our favourites and thats that
im sure the big names in perth will all do a pretty good rebuild , its not rocket science
Edited by arkon
Tomei Poncams
Heavy duty valves
Headstuds
HkS timing belt
u seem to know what you need to get a good RB going(judging from list), someone recommended all these parts to you or you knou your stuff. maybe you should ask the same person to recommend a workshop to you or you already know the answer to your own question.
I really didnt think this thread could last 10 and a half hours ha ha
Check the consolidated workshop thread, ring around, find someone you are comfortable and trust, then give them your parts. Cost should not play a huge part in a build like this.
mayb wen u spend $20k on ur engine.....looking for a workshop to do a good job/price would be of use to you....But in ur case....installing a pod filter then i surpose any old person would do
sarcasim is not one of your strong points obviously
or mine perhaps......
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
