Roy Posted March 1, 2009 Share Posted March 1, 2009 I love your loyalty to this project. I am not selling my RB26 bottom end now. Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/11/#findComment-4451964 Share on other sites More sharing options...
SteveL Posted March 1, 2009 Share Posted March 1, 2009 .. moves so smoothly compared to the other one you needed a spanner to turn the crank. Doesn't that tell you something ?? Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/11/#findComment-4452041 Share on other sites More sharing options...
murrayis Posted March 1, 2009 Author Share Posted March 1, 2009 (edited) I love your loyalty to this project. I am not selling my RB26 bottom end now. lol Thanks... its been 2 years in the making so no point giving up on it now.. Doesn't that tell you something ?? Yea I put it down to us increasing the oil clearance this time by another ½ a thou, and the fact when I tried it last time it was after It had spun a big end and a main bearing. Anyway, I spent today doing as much as I could in the 36 degree heat! I spent a good 2 hours cleaning out the Sump and Head, I couldnt believe the size of the bits of bearing the I got out of the sump, I ended up filling it with water and putting a few welding magnets in the water to pickup all the small particls and large flakes a bearing. The head took the most time as I didnt have the tools at home to remove the valves so it flushed it slowly cleainng out all the oil and any small traces of bearing I could find... which was only 1 or 2 specks. I installed the Sump, Oil pump, Rear Main Seal, Exhaust manifold, Turbo and the Head today. I held off with the water pump due to a couple of the bolts looking a little worse for wear I shall pickup some replacments from nissan this week. Anyway heres a couple of picctures of where I am upto. Edited March 1, 2009 by murrayis Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/11/#findComment-4452177 Share on other sites More sharing options...
murrayis Posted March 1, 2009 Author Share Posted March 1, 2009 I have been looking over my figures for the head bolts of what I had written down a year or so ago, can somsone confirm these for me. 1. Tighten to 22 ft/lb 2. Tighten to 80 ft/lb 3. Loosen bolts completely to 0 ft/lbs 4. Tighten bolts to 22 ft/lbs 5. Turn bolts 85-90 degrees clockwise with an angle wrench, or tighten to 76-83 ft/lbs when torque wrench is used. From looking over the nissan manual these appear to be the rb26 standard torque settings, and ARP recommeneds 109ft/lbs as the final figure is this tru for the rb20 also? I am using ARP studs for the head. Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/11/#findComment-4453097 Share on other sites More sharing options...
Swiper the Fox Posted March 1, 2009 Share Posted March 1, 2009 I have been looking over my figures for the head bolts of what I had written down a year or so ago, can somsone confirm these for me.1. Tighten to 22 ft/lb 2. Tighten to 80 ft/lb 3. Loosen bolts completely to 0 ft/lbs 4. Tighten bolts to 22 ft/lbs 5. Turn bolts 85-90 degrees clockwise with an angle wrench, or tighten to 76-83 ft/lbs when torque wrench is used. From looking over the nissan manual these appear to be the rb26 standard torque settings, and ARP recommeneds 109ft/lbs as the final figure is this tru for the rb20 also? I am using ARP studs for the head. 85ft/lbs with moly lube will be sufficient. Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/11/#findComment-4453109 Share on other sites More sharing options...
murrayis Posted March 1, 2009 Author Share Posted March 1, 2009 Thanks Paul, If I don't have any molly lube and use 30w oil what do you think bump it upto 95ft/lbs? Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/11/#findComment-4453114 Share on other sites More sharing options...
Swiper the Fox Posted March 1, 2009 Share Posted March 1, 2009 Thanks Paul,If I don't have any molly lube and use 30w oil what do you think bump it upto 95ft/lbs? do you want me to post you a tube? Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/11/#findComment-4453115 Share on other sites More sharing options...
murrayis Posted March 1, 2009 Author Share Posted March 1, 2009 Thanks anyway, The head is already bolted down and studs have 30w on them. I used the last of my molly lube on the ARP rod bolts. Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/11/#findComment-4453120 Share on other sites More sharing options...
Swiper the Fox Posted March 1, 2009 Share Posted March 1, 2009 (edited) Thanks anyway, The head is already bolted down and studs have 30w on them. I used the last of my molly lube on the ARP rod bolts. its generally 20-30 more ft/lbs when using 30W oil for that size stud...so 109ft/lbs sounds like the right torque for 30W oil. Edited March 1, 2009 by DiRTgarage Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/11/#findComment-4453127 Share on other sites More sharing options...
murrayis Posted March 1, 2009 Author Share Posted March 1, 2009 (edited) Thanks Paul, I'll go re-torque them. (EDIT) Done & Done Edited March 1, 2009 by murrayis Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/11/#findComment-4453146 Share on other sites More sharing options...
Swiper the Fox Posted March 2, 2009 Share Posted March 2, 2009 Thanks Paul, I'll go re-torque them.(EDIT) Done & Done sorry i didn't reply to your email Cameron...only just checked it. I suppose you dont need me to address the questions you asked in it now as your done. Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/11/#findComment-4453413 Share on other sites More sharing options...
murrayis Posted March 2, 2009 Author Share Posted March 2, 2009 Paul, I ened up with 2.2 thou clearence on the mains and bigends. Does this sound about rite? previous we had it at 1.5thou Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/11/#findComment-4453586 Share on other sites More sharing options...
huddy Posted March 31, 2009 Share Posted March 31, 2009 any updates on this? i'm missing my RB24 need updated running vids Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/11/#findComment-4510624 Share on other sites More sharing options...
rodger1 Posted April 3, 2009 Share Posted April 3, 2009 any updates on this one? will be good to see what she puts out Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/11/#findComment-4515973 Share on other sites More sharing options...
murrayis Posted April 3, 2009 Author Share Posted April 3, 2009 (edited) No updates really... The engine is sitting in my garage while I contemplate If I should do a external oil pump setup on it or just a billet pump. The clutch is off at Jim Berry's being rebuilt so once I work out whats going on there It will be back in and running again.. Could always drysump it Any ideas what I should do? Edited April 3, 2009 by murrayis Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/11/#findComment-4516081 Share on other sites More sharing options...
huddy Posted April 3, 2009 Share Posted April 3, 2009 dry sump if you've got the cashola In my 26/30 build i think i'm going a powertune gearset for the oil pump - it's billet and looks the goods... mated with the oil restrictors, external oil drain, baffled sump, moroso oil accumulator i'm hoping the oil system should be fairly good Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/11/#findComment-4516253 Share on other sites More sharing options...
murrayis Posted April 3, 2009 Author Share Posted April 3, 2009 (edited) Ha nice! Yea I am not sure what to do... Jim Berry just called Clutch is ready So I'll be picking that up on Monday Got a link or info on those gearsets? Edited April 3, 2009 by murrayis Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/11/#findComment-4516271 Share on other sites More sharing options...
huddy Posted April 3, 2009 Share Posted April 3, 2009 there's the link - nevermind the 'rb26' i spoke to them and they can fit it to the pump you are using (for me it will be rb30) http://www.powertune.com.au/rb26parts.html Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/11/#findComment-4516281 Share on other sites More sharing options...
murrayis Posted April 3, 2009 Author Share Posted April 3, 2009 Nice, good thing I am using a Rb26 Pump then May have to investigate that as a cheaper option. Cheers Huddy. Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/11/#findComment-4516298 Share on other sites More sharing options...
murrayis Posted May 3, 2009 Author Share Posted May 3, 2009 Nothing much to update, Spent last Sunday putting the engine back in the car hat a mission it is to line the gearbox up with the engine! I wont be doing that again in the car. Today I was planning on getting it started etc so got all the wiring done, water and oil lines hooked up radiator and starter motor in... put 7 ltrs of oil in and started to fill the radiator and my feet were getting wet! Somehow I have lost the plastic bung out of the radiator I suspect one of the dogs as picked itup as a chew toy like they have done with the silicon tubes. So I am on the hunt to find a new/replacement bung for the ASI radiator, I have emailed ASI so hope I can get a replacement from them. Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/11/#findComment-4570723 Share on other sites More sharing options...
