iv been thinking for ages how to design this and have tried several ideas , from a tight bowl around my pod , to trying to make bends with aluminium around the afm and cables etc.. iv seen some other designs out there , some work some dont ..
what iv done is basically scribed around the wheel gaurd , attatched the afm through the frame . i aslo have a CAI comming up through the stock intercooler hole which will feed my cold air ... although im hunting another idea where the stock snorkle was , although sold mine .. so im thinking of making something similar .
all i need to do now is prep and paint with some heat proof paint . possibly black so it looks stock - hehe
tell me what you think , here are some pic... cheers
https://www.sau.com.au/forums/topic/165238-pod-enclosure/
i was going to use aluminium ... but this stuff is like steel i think , its about 1.2 mm .. its not easy to work with . i didnt buy it , i picked up a few sheets around where i work , in an industrial area ... its easy to bend , but was tough to do the fold over on the top panel ... if i were to make some more id be considering using thinner material .. because itll make things so much better to work with ...
but im happy with how strong it feels ..
https://www.sau.com.au/forums/topic/165238-pod-enclosure/#findComment-3061131
If you post up a few more details..
Like parts used, approx cost, tools required etc.
I'd like to move this over to the Fabrication section as its definately worthy of going there to help future people with stuff :P
Lemme know
Cheers!
https://www.sau.com.au/forums/topic/165238-pod-enclosure/#findComment-3061173
alright here are all the details i have on how to make this / and how much it cost .
tools needed :
- stanley knife
- tin snips
- grinder
- scissors
- pen / black marker
- 3 mm drill bit
- battery drill
- philips n1 bit - for drill / or screwdriver
- 76mm hole saw / H.S.S (quality is a must )
- 10 mm drill bit
- pliers
materials needed :
- cardboard ( approx 2 @ 400 mm x 200 mm ) = free if you can find.
- 1 - 2 mm aluminium / tin / steel .( approx 2 @ 400 mm x 200 mm ) = unsure on price . wont be more than $10
- 15mm philips head screws , threaded type = $3
- L type metal brackets = $5
- rubber from a fly screen / or safety - fold over protector = $7
basically this is really easy in writting but takes a bit of practice .
1/ get your card board . remove afm and anything in the way . the easiest way to scribe the shape of the wheel gaurd is to estimate the shape of the round and cut it on the carboard. also attempt to cut the part that runs flat along .. you can either do it in 2 peices then tape together .. or do it in one like i did
2/ once you have scribed the shape . transfer it onto the steel/tin you decide to use ... using high quality tin snips . cut out the shape . also cut a square approx 1 cm x 1cm for the cables to run through that sit on the flat part of the body .
3 / once you have cut it out onto the steel , grab your AFM . now trace the 4 screw holes . and measure and mark the centre for the 3 inch air flow hole (76mm) .
4 / collect your hole saw and drill the centre air flow hole .
5 / using a 10 mm bit or smaller drill the holes for the scews .
6 / on the aluminium - drill 2 holes aproxx 5 mm from the bottom , on on either side . these are to screw and hold the frame to the lower body .
7 /using the rubber from a fly screen . cut the length of the frame so the rubber can sit along the bottom of the body . grab your stanly knife and slice it all the way down the middle .now you can slide it onto the bottom of the frame .
8/make a bend in the frame . this has to be along the wheel gaurd. then screw the clips onto the frame / and screw the frame to a spot on the body .
9 / now grab your other piece of cardboard and sit it over the top . mark around the cardboard where the curve follows , and estimate the the angle of the front body .
10 / in between your estimations you will find you will need to cut more off and if your unlucky add more to your template .
11 / once this has been cut correctly . you will now trace it onto the other bit of steel/tin . although when cutting , add another 10mm along the straight edge to allow for the over hang / fold over.
12 / once you have traced , cut it out yet again - also mark the 10 mm line along the angled part . and sit it over the top for positioning . you will now need to mark the point where the angle meets . then you will cut a line 10mm so that you can have to seperate fold overs .
13/ using your pliers you will now bend the fold over to the line you marked..
14/ if you used thick material like i did , after bending and folding you may need to grind it down so its flush .
15 / now you should be able position it over the top .
16 / if all was done well , all you have to do is grap your L type brackets and sit them over the top and overhang on the sides... grab a pen . and mark the hole positioning . grab the drill and drill into the frame and top . last but not leastly , screw your screws in . now your DONE!...
17 / paint the frame and top for a more original look . specifically heat resistant paint .
i will post up some pics once i have painted mine ..
cheers = must add to DIY section or so forth .
https://www.sau.com.au/forums/topic/165238-pod-enclosure/#findComment-3061369
Well mate I reckon what you've done is a great job, simple yet effective.. However, I must ask this, what if one was to have a twin pod intake? obviously that would complicate things substancially....
https://www.sau.com.au/forums/topic/165238-pod-enclosure/#findComment-3061423
your talking a GTR i take it ? nothing is impossible , its more patience and accuracy . planning ahead is a must , basically if you make the right template , your set . also if 2 pods can fit in an engine bay on a GTR or anything for that matter , you will surely be able to make an enclosure with the right design.
https://www.sau.com.au/forums/topic/165238-pod-enclosure/#findComment-3061430
Nah it is a GTT R34 actually, so it would be the turbo Rb25NEO. Just asking what your opinion would be, cause by the look of things, you've got a nack for this kinda stuff, I like what I see... I suppose as things become more cramped and congested, it would require one to be more meticulous and precise? I have seen some Skylines with twin pods... Do you think that twin pods would be a tight fit?
https://www.sau.com.au/forums/topic/165238-pod-enclosure/#findComment-3061457
to marco :
iv seen the small baby apexi pod filters . they are tiney , but still an adverage size pod filter . it would just be more time consuming , you just need to think out how its going to be done .
thats the way i did mine . had a good look in the engine bay , thought for a day or 2 , went back and had another look - then i came to my decision of how i would go about . but bolting directly to the afm was the best idea
1 / it supports itself in the frame - which saves you mounting them .
2 / make the whole frame stronger .
if your thinking of doing a twin pod setup , PM me , id be more than willing to throw a few ideas at you with the easiest way to do it .
yet again thanks for the good comments guys , glad to see good work can be appreciated these days.. cheers :nyaanyaa:
https://www.sau.com.au/forums/topic/165238-pod-enclosure/#findComment-3061709
Looks good. I am just about to make something like this for my R34, but I was thinking of using fibre glass to make it. I haven't worked with fibre glass before so hopefully it will go OK :nyaanyaa: I was goind to do the same thing but make it fully enclosed if possible.
https://www.sau.com.au/forums/topic/165238-pod-enclosure/#findComment-3061832
Nice job there matey (not criticising your work), but imo, it defeats the idea of having a pod. the closer you get to fully enclosed, the closer you get to the stock airbox
how so?
he has a cold air feed to the pod from underneath it leading from his front bar. try doing that with the stock, restrictive, paper filter'd airbox.
good job with the box mate, looks very neat. only thing i'd suggest is insulating the inside of it somehow so the heat from the metal doesnt radiate into the pod.
https://www.sau.com.au/forums/topic/165238-pod-enclosure/#findComment-3062002
thanks for the comments fellas . i will be taking note of insulating the insides . pics will be up early tomorrow morning of how it comes out after is has been painted .
and also for those interested i will take a few photos of templates
https://www.sau.com.au/forums/topic/165238-pod-enclosure/#findComment-3062055
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
