  • Replies 59
Originally posted by GTS-t VSPEC
Byaley, Driving a Corolla and VN must make it hard to speed:p
Hay, that Rolla cops it! Foot flat, hit rev limiter, go to 2nd, hit rev limiter, go to drive! I drove a GTS-X for 6 months! I am nowing driving VN 5ltr. I speed EVERYWHERE! Just lucky I think!
heeh well i got outta a 6point fine too I was tailgating an unmarked police car, 80 in a 60 zone, 80 in a 40 zone and i must admit to wearing a very short skirt that day haha
I have a radar detector but even thats not going to save you at more than 10kms over the speed limit. They just dont give enough warning.
Gotta agree with Dan and GST-T VSpec, guys very rarely get let off for anything, while a female friend of mine was left off for 120 in a 60 zone while on P's a few years back. I get busted for 5kms over the speed limit in a 100 zone. LOL
Well all this talk about fines and points... bah, got pulled over today by a cop with a radar gun on my way to work... 73km in a 60km zone, $100 fine and 2 demerit points... bah :D Least he didnt say anything about my intercooler, chopped front bar and number plate stuck to one side :P
First 12 months of having a license (in a 95 lancer)
1 point speeding (70 in a 60)
3 points speeding (90 in a 70)
2 points speeding (90 in a 60)
6 points speeding (160 in a 100) $350.00
Lost license 3 months.
3 points running a red light.
Bought skyline.
(12 months of owning my skyline)
3 points driving with a blown headlight.
2 points turining at a left turn only, without indicator.
4 points remaining.
Guest KMale
I have lost my license a couple of times over the years but not recently. My demerit points tend to hover around 6 - 11. I tend to get got by multinova's doing 70 in a 60 zone ...you know those crazy duel carriageway 60 zones that could pass for freeways.
Anyhow ...I am convinced it all depends on how much driving you do. I do about 30,000 km a year so I guess my exposure to multinova's is greater than the average person who drives to work and stays there.
lost 12 points and licence in the first year of owning the car (92 n/a silvia) , lost licence for 3 months, and they gave me another year of p's when i got the licence back.
Lost licence roughly another year after that.
Lost 3 point during that time before they came round to get my licence, so i was down to 9 before i even started driving again.
Lost another 3 for some stupid 50kmph cr*p.
Crashed silvia in freak driving mishap at collie racetrack.
No fines whatsoever in skyline since, i think i'm a changed man.
still speed though...
Damo.
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
