  • Replies 369
Posted Images
yes they look very similar..
and yes mine are quite heavy, but i wouldnt swap them for anything else... :worship:
what brand are yours? Mine is HR Racing - not sure if they will be suited for track work and what not - I think its more for looks - but i aint complaining :)
And yeah - like yours, mine are quite heavy as well :)
mine are RTG.. never had heard of it before i bought mine..
heres my baby!
Thats One Nice R32, sweet Rims, Dont see to many these days. Expect to see me around Croydon in the upcoming weeks, tearing it up, ill b Working at the Telstra exchange, wherever the hell that is.
cheers, yeah heaps of bad examples around these days... although there are a few nice ones getting around croydon and a sweet black GTR too. I dont even know where the telstra exchange is lol.
free to a good home.....lol
animals seem to luv skylines.....sometimes when i go outside to see what my beagle is up to - i find him licking my car! stupid dog.....and this happens after i wash it.....
one occassion he growled at me for getting close to him and the car..... :)
Yet you still drive a GTST :)
Had no choice - didnt have the money then (and dont have the money now either) to afford anything over 17k, But had this car been on sale when i was looking for a car, and if i had the money for it - it'd be sitting in my garage this very minute :( - i mean look at it, its mint!!
All I was trying to say is that, people are advertising their gtts and stuff for ridiculous prices, dealerships have 33 gtrs for mid 30's, and this is a mint 33 gtr for a very reasonable price - yet it doesnt get sold. And then you get the tire kickers, who just go around to give the car a bit of stick just for the hell of it, then they offer something like 20k?!?!?
kthnx
Edited by emsta2003
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
