  • Replies 369
Posted Images
Haven't seen you in ages Jackie. What you been up to?
Hey Al how u doing?
Ive changed sections in my job n sort of running a new contract now so i dont get to jump on here as often as i once did
But havent been up to much just working heaps n stuff.
How about u, what u been upto?? hows ur beast?
Hey Al how u doing?
Hey Jackie,
sorry for the delayed reply.
I am pretty much the same, working a fair bit, trying to organise my rental property and fixing the car.
Not sure if you heard, but i lost comp on piston #3, after a track day, and am now in the process of a full re-build with all the "bells and whistles". Hoping to have the car back by August, just in time for DECA, but that is still not 100% :P .
Hey Jackie,
Not sure if you heard, but i lost comp on piston #3, after a track day, and am now in the process of a full re-build with all the "bells and whistles". Hoping to have the car back by August, just in time for DECA, but that is still not 100% :D .
Sorry just been abit busy to reply
Ouch thats not good, but atleast its gonna get a nice new re-build. I'd b happy to re-build mine n do it up more but just dont have the time nor money.
Hopefully ill b at deca in August, i havent done it in so long so ive gotta get out there n give it another shot, it was so much fun.
Plus Wayne (ARCHOO) wants to race me again lol, its a good even race with me n him.
Good Luck with it all though
Bring it on Jackie :thumbsup:
  • 4 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
