Vic Members Rides
jippa3000
  • Replies 369
Posted Images
I could swear I had posted in here before but apparently not...
Anyway here are the skylines I have owned....
The first...a 95 gtst:
...and here is my recent work in progress..a 97 gtr:
post-6243-1185489275_thumb.jpg post-6243-1185489285_thumb.jpg post-6243-1185489295_thumb.jpg
...and with my new track rims :thumbsup: :
post-6243-1185489339_thumb.jpg post-6243-1185489355_thumb.jpg post-6243-1185489347_thumb.jpg
Agreed!! Care to share the size/offset with us?
Cant beat those headlights too! Does your interior have red stitching Ant?
So far ive narrowed down that style in S3 R33 GTR's dunno if its all of them though :P (or if im right)
Mr Jordan, throw up some pics of your airbrushed bonnet :D
LOL fooled me :D
Not a big fan of airbrushing (although i want a tiny piece on my car), but i reckon that would look just nutz!
Whats it from World Industries or sumfin? I know they got the flame dude, but that style looks familiar.
Hey
Just got my car on the road few weeks ago, It was such a nice day i thought i would take some pictures. (Sorry if they are to big)
Also a Massive thanks to Simon (FLYSLY) for lending me some tyres so i could get the rego :D
So far ive narrowed down that style in S3 R33 GTR's dunno if its all of them though (or if im right)
Thanks for the comments guys ;)
Size of tracks rims are 18 x 10.5 with a +18 offset
You are correct....the xenon headlights and red stitching are features of the series 3 GTR's as well as a few other little bits and pieces.
    • Blitz ER34 at some point hopefully, should be allowed in Gr3 if they do.
    • Stock R33 boost control, with the exhaust, and FMIC done, will boost creep. There is no tuning around it if it is the factory boost solenoid.   If it has an aftermarket electronic boost controller, the settings/mapping can be altered in it.   Oil could be anything as mentioned, however did it ever do it before you did the turbo swap? How much and how often did you drive the car before the swap?   I'm hinging on too much oil supply, or it's not draining properly.   To check, pull the air outlet off the turbo. Is it full of oil? Drop the exhaust at the turbo, does it appears to be oiled/coked? Now pull turbo and check the exhaust manifold, does it appears oiled and coked the same way?   Secondly, the PCV could even be stuffed / not functioning properly and will cause blowing of blue smoke.
    • Almost any ECU would work, from a 30 yr old PowerFC to a new Motec/Autronic. But presumably you want new middle of the road ECU, meaning that you want a Haltech or a Link, most likely. As to which model though? I dunno. I don't keep track of what they have in their current ranges. You don't want a plug in though, because plug ins can start to cause you the same wiring issues that you have to chase up with your stock ECU/loom swaps when an engine transplant is involved. If you use a Haltech (and presumably a Link) you could put the base map for the engine in and drive it around and not even need to "tune" it. It will work just fine. I can't recommend a tuner without a location (and even then I can't recommend many, being as I never use any tuners except myself and my brother-in-law). And not many tuners are happy to remote tune. Maybe they'd be happier doing it for a basically stock setup that just needs to be demonstrated to be working properly. But even then, not being able to be with the car to see what the hell is going on and sort out the inevitable problems that will result from an engine conversion done by an amateur..... unlikely to be enthusiastic about the job. And if you think that just adding 2 wires for the boost sensor is difficult - you don't want to be trying to install and set up an aftermarket ECU. You're going to have to bite down hard on something with either approach.
    • wired everything up and confirmed that the red with white stripe is indeed the fuel pump pin on this harness.
