Re dyno'd my GTR yesterday, totally different power curve :)
Made top power about 6000rpm
166kw's in 4WD & 185kw's in RWD
Graph coming....
check last post
Hey people,
Had my R32 GTR on a Rwd dyno today, it made 176kw's. Not sure about the rpm level, but it made peak power at 101km/h. The only mods so far are a K & N panel filter and a TRUST 80mm cat back exhaust system. Apparently the boost restrictor has been taken off?? bcos it was running a solid 12-13 psi. Is this about right? Anyone roughly know what kinda power increase's a full exhaust system will make.. Any suggestions on next mods.
cheers
Jono
GTR 032
https://www.sau.com.au/forums/topic/16675-my-gtr-on-dyno-today/
I think you're mixing up the torque and power lines Dundan.
Power is the red one, and rises gradually to ~175kw and stays there until redline.
Torque is all over the place. Weirdest torque curve I've ever seen. What's with the dip at the start?!?
In fact the flat power curve is very very weird too...
That's one weird-ass dyno reading right there. Stick with Dyno Dynamics :)
/me writes down "MDXDYNO... Never use".
The dyno guys didn't really say too much about it, get what you pay for I guess... Gonna try a little more reputable dyno next time. The power curve on my GSR was very straight forward to read compared to this one, except that it had bags less power..well not that much :)
Cheers
One weird looking dyno graph!In fact,the power curve looks a lot like the torque curve.I mean, when was last time anyone ever saw power curve dead-flat?Definetly looks like torque.And torque looks very much like the power curve.Except it peaks too early and drops-off too quick to be the power curve.Strange.Could be that the dyno parameters/software were not set-up correctly before the run or something.One weird looking dyno graph.
that is seriously confused. Sure that wasn't made with a spirograph? ...sorry. But it is a weird graph. Use search, and look for 'dyno' - there are may of the guy's dyno sheets on here and you'll probably be able to find a 32 GTR dyno sheet somewhere to compare it to :)
Is that the wheel spinning run? That may explain the apparent power loss. Also that torque figure looks a little unrealistic. 32/33 gtr pull 350-360 Nm at around 4500 rpm stock.
Just remember that power = torque x revs. So as torque drops and revs rise power stays flat.
My guess is wheel spin (and the values are too high). What you've got there is wheels breaking traction at 100kms as the torque ramps up and the correction values on the dyno giving a very high reading.
Cheers
(Professor) BHDave
I'm with Dave, that's the sort of result we get when there is wheelspin. The resistance at the rollers gets to a certain point and then the tyres slip on the rollers. So it always shows the same max power as the wheelspin increases and holds the readings constant. It can be bad enough to affect the power readings, but not bad enough to smoke the joint out.
The torque readings are being affected by being in 3rd gear, that may be the reason why they are higher than usual (in 4th).
I'd suggest another run but in 4th gear and tied down better to the dyno.
Hope that helps
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
