Got my mit's on a NOS EFI kit (wet).
Just the thing to go with my 600HP fuel pump I thought.
All I need to do is fit it (a couple of hrs) and fill the bottle.
I'll set it up with a 50HP jet and get it sorted nicely so the person who buys my car can drop a 100HP jet straight in and go pull 11's if they get some decent rear tyres.
https://www.sau.com.au/forums/topic/16683-got-my-nitrous-kit-now-im-happy/
  • Replies 62
it would blow more than his bloody floor off.. i dont see how the hell that someone can blow the floor off... i mean, sure, if the floor was riced out to the max like that one probably was... all the tar removed, floor cut for weight reduction (even though the ricer kits weight a tonne) .... i hate that movie.. except for the S14 and the R33... mmmmm :) theyre rice... i mean nice.
lol .. yeh my gf's friends go "so is that what dragging is like?".
I laughed for so long and told 'em that if they were 10 - second cars, the race wouldnt go for so damn long. Not that I know anything about street dragging but You'd think the producers would work out the obvious .. :D
greg,
What you don't see can't hurt you.
Paul,
The amount of nitrous power you put in is exactly the same as any other kind of power upgrade.
Your engine internals have a limit, your fuel pump has a limit and your drivetrain has a limit. Don't exceed them and your fine.
I'd say on a stock turbo'd R33 you could go a 100HP shot without a care in the world. That usually will end up being pretty close to 80-100hp extra at the tyres due to the extra effects it has on a turbo 2.5L. that puts you in high 300's at the rear tyres.
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
