  • Replies 94
It is JUST A BLOODY SERIES DESIGNATION.
Just because three unreferenced Japanese sources have another goofy response to turn RB into an acronym doesn't make it real.
EXACTLY!!!!!! PLEEEEEAAAASSSSSEE SHUT THIS THREAD DOWN, it will achieve NOTHING.
It means f**k all, its just codes for series of engines.
All of the Race Bred, Response Balance shit came after it was out. not during the naming process
Call it what u want, each to their own. but it doesnt actually mean anything.
I'd like to know what some of the following nissan engine codes "Mean" then. hah
CA, LD, KA, MA, QG, CD, CG, E, FJ, L, RD, SR, TB, VG, VH, VQ, Z
here we go... *waits*
all these people are correct, that includes me:
omfg cant manafacturers just pick 2 random letters for a engine family ID anymore?
its just a 2 digit combination they use to ID the engine from other Nissan engines, not this race bred or repsonse balance shit.
just close this down. whatever it stands for, its in our skylines so just respect it. if you had to interpret what it means or stands for - just say, something that is damn fast!
Mwahhaha... brilliant. :rolleyes:
We had a fairly useless rumour (RB = Race Bred), it got attacked by something to the contrary (RB = Response Balance), the whole thing ends up getting argued about so much it's almost rediculous - for such a trivial thing - and after 5 pages most sensible people agree that 'RB' means nothing... Perfect, just how it was planned :)
Thanks for playing guys!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
