HI Everyone
Warning this maybe a silly questions for some but im still learning about boost and turbos Thanks
i have a delema i have heard that on stock intercooler and stock turbo the most u can boost is 14psi and the setup goes bang bang bye bye. so my questions is if you get a bigger intercooler can you boost it up to 15-16 psi or is the turbo going to got bye bye or do u need a high flow turbo if you want 15-16 psi
any help is muchly appreciated sorry if i posted this in the wrong spot
Thanks :rofl:
https://www.sau.com.au/forums/topic/167257-when-turbos-go-bang/
the general rule, is max boost for stock turbo is 14psi; most people have found this is where the turbo makes its max power, so even if you turn up the boost doesnt mean you will make more turbo.
If you want to run more boost, then look at buying an aftermarket turbo or getting your stock turbo highflow
^^ was about to say the same thing.. PSI is just a measurement of the pressure in the manifold.. A high-flow running @ 14PSI will generate alot more air than a normal turbo running @ 14psi..
Also - as you've got a R33 Gts-t, advised boost on stock turbo is 10 - 12psi, any more and you risk shattering the ceramic exhaust wheel..
thanks for all the input i think i will get a intercooler and run the lower boost like link said. i dont want to spend big money on all this. if i do have a bigger cooler and run 8psi daily driver and 12 for race day will this work okay and not ruin anything to quick. i dont want to hear bang ssssss when some thing decides to die on its arse haha
thanks
OK as Links said, I would NOT advise going over 12psi, 14psi is too much, WHY? 33gtst have a ceramic wheel in the turbo, great for low spool due to how light it is however it cracks and shatters under heat.. NO a turbo timer will not resolve the issue. Its when its at full boost etc when it gets too hot and out the exhaust pipe it goes.
In summer I would not go anywhere over 10psi, i have been through enough turbos now to advise you of this.
mine still went at 11psi from standard wheels, so now have high flows, I am now on my third high flow and i recommend not taking high flows over 16psi... sure i can put it up to 22psi but it dont last long! a general highflow of the standard turbo i would not take over 16. remember 4psi from a high flowed turbo is more than 4 psi from a standard turbo.
I have generaly paid about $1000 for my highflows. I love highflows, still the same low spool due to the same housings etc and a nice bit of boost.
By the way shenron i saw you on the freeway tonight, i was in my 1979 laser at the time so not noticable.
Before you get intercooler I would do ecu or SAFC to get air fuel mixtures sorted PLUS a dump and down pipe from your standard turbo, i managed to putt 290rwhp off standard turbo which back in the day was quite good....until it blew :-(*
i would get the intercooler before I get an safc or ecu
lower intake temps , less heat and stress and far less restriction than the stock cooler . assuming you have a full 3 inch exhaust 1st .
free up these restrictions 1st before you try and add more power through boost/ecu
i have a 3inch dump pipe straight though to a canon and i have a pod and so fourth so then next mod was going to be the cooler but i will take this in to my budget to see what i can afford and go from there thanks for the advice.
was ur laser white i think i saw one laser surprising i didnt try race u haha there was a volvo and a prajero that want to run last night and a celica hahaha.
You got 290rwhp out of a standard turbo and ecu? What sorta mods did you run?
Sorry Jie should have explained myself better - Was running SAFC and ITC Combo so fuel and air plus ignition timing was looked after.
what else? dump down pipe... the cat went for a walk for a little while in the exhaust but she came back now, fuel pump, Blitz duel SBC air filter.... then the usual after that, cam gears advanced timing etc etc. It DID have and still has one of the most expensive coolers on the market (custom made by Micks Metalcraft) installed at the time my quote above though was based on the fact that the standard turbo with supporting mods can make nice power.
Ummm yeah the dyno was recorded on the Dyno dynamics at PSI so we may have a bit of a problem getting it off there. Both mine and gtstvspec managed to get that kind of power but paul had a nice greddy plenum attached to his.
Even at 12 psi the turbo blew...... maybe with Pauls plenum thats why his turbo didnt blow like mine... or did it?
I thought a nice turbo backe xhaust, fmic, safc and a boost controller would yeild 260-280rwhp normally in a gtst at approx 11-12psi on stock turbo
mmmm tempting to get back into a skyline lol
im running a series 1 rb25 on an rb20 (series 1 is mean to be smaller/weaker) and i have been running it at 18psi for the past 2 months and it has not had a single problem lol. It doesnt matter if it does blow because the engine and turbo are just temporary, but yeah just thought id add that in haha. Not a single problem so far.
    • A realistic expectattion of how long it has to last also comes down to.... when do you think you will be banned from registering and driving old petrol powered shitters? It's 27 years since that thing was built. It probably rusted out 15 years ago. It was probably repaired and looked OK for another 10. If you do a similarish bodge job now, or perhaps slightly better with some actual rust conversion and glassing, then.... get another 10-15 years out of it, after which you'll only be permitted by the CCP to drive electric cars manufactured in their Shenzen zone anyway.
    • Let me assume that the concern over a manual ECU is that the NeoDET that you have was an auto and has an auto ECU. That ECU will not be a problem, but you WILL have to Nistune it. And you would have to Nistune it even if you had a manual ECU, because the turbo ECUs will shit the bed if they do not have all the things that they were told they have to have, to be happy. The big one being the TCS CU, which you won't have in your car. Anyway, with an auto ECU (which I have running my originally auto NeoDET in an R32) Nistune allows you to put in a Stagea image which doesn't panic about the absent TCS, and allows you to override a whle bunch of other annoyances that would otherwise see the check engine light on 100% of the time. Also, you can't wind up the power very far on the stock NeoDET ECUs without Nistune, because the boost sensor gets in the way. Nistune allows you to push that problem much further up the dial. Do you even have the boost sensor with the engine? Without it, you are SOL and will need an aftermarket ECU (or to find a sensor somewhere, god knows where). I can't tell you what the wiring loom differences are in a 34. But what Duncan said above needs to be considered. When you say "loom", does that include the transmission loom? Because you will need to swap out the auto tranny loom for the equivalent manual loom, and get rid of the neutral/park start interlock (basically hot wire it).
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
