The GTR got in it with the R32 at number 26 (decrementing to zero)
http://www.topgear.com/content/timetoburn/...fastestcars/76/
I think whoever wrote these comments (first sentence and last sentence) underneath got it spot on. :( :laughing-smiley-014:
Check out the rest of them, plenty or porsche's and ferrari's in the higher numbers.
https://www.sau.com.au/forums/topic/167415-top-gears-fastest-100/
You know their opinions are bullshit when they rate a Renault Clio 25 and a GT-R below it. I hate top gear they're so bias for euro cars that are total crap.
Top Gear always bias for pomy poof cars. Especially the piece of crap Mclaren SLR they think its god!
http://www.youtube.com/watch?v=h1Y-1yI1hdI
Top Gear is a joke. It's more of an entertainment show, than a serious review of cars. If you want a proper review from a professional driver, watch 5th gear with Tiff Needell. Jeremy Clarkson is a comedian, and that's where it ends.
Bring Tiff back to TOP GEAR!!!
Yeah I dunno, along our 'V8 championship' I'd like to see a parallel series that includes the likes of the GTR, 350Z, NSX, S2000, RX7, RX8, WRX's, EVO's, M3's, A6's and the likes...
REAL racing machines...
Edited by Marco-R34GTT
Huh? A6s as in Audi? And really what is a wrx, an evo, and a M3? The hotted up versions of the standard car, much like an SS or XR8...?
Either way back on topic. Its just a list. I can do a list up too which I would think is more accurate than that one.
BTW topgear the show bag out pretty much everything other than German cars (yet they still find faults) and Ferraris. They reallllly rip in to french cars, most British cars, and obviously American cars.
I was just brainstorming, but yeah, I get your drift...
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
