  • Replies 240
we have a few cars to put on the rollers as well.
easy st r32 gtr 600hp at all 4....
hijacked r32 gtr 500 hp
willo r34gtr 500hp
urnext r32 gtr high 400hp
nsm033 r33gtr 470hp
possible theos castrol edge r32 gtr... big hp.
cheers...
Put me down Col.
:whistling:
Put me down for sure..
Fuel problem sorted for this one....
Awsome, will be good to see how she goes...
i would be very keen for that...... if you guys dont mind an evo showing you up :)
*runs and hides in corner waiting to be flamed*
Your more than welcome, we may appear to be die hard skyline owners on the surface. But im sure most would agree that we all enjoy a fine motorcar and I pay where credit is due and would love to see a few Evo's run the rollers...
hoping my engine is done for then. see if we can get atleast one Shane to take his RB30 power down for a run
That would be nice Shane, It seems shanef is too busy riding bandwagons :P rather than working on his car...
Col put me down for a pending place for a friend.
300rwkw++ Gtst
I got ya covered Josh...
ill bring the ceffy out for this, also Series 5 might bring his rotor out if thats cool?
Please do, ceffy are a part of the skyline family and a rotor in the mix would be fantastic...
Count me in also
Awesome Cam, are we expecting to see the Evo or the GTR??? Please say both :P
now i cant wait to see all them gtst owners cry :)
Col sings: "All aboard the Bandwagon, come ad see me on the bandwagon. I am a GTR owner with no guff" :P
That would be nice Shane, It seems shanef is too busy riding bandwagons :) rather than working on his car...
Col sings: "All aboard the Bandwagon, come ad see me on the bandwagon. I am a GTR owner with no guff" :)
read my recent posts u assclown, new head = heaps mroe delays :P
you should know i only do it to stir yas up :whistling:
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
