Ok guys, im bringing the tradition back.
Enter the return of the Team Northside Dinner.
Kicking things off, the June official TNS dinner will be held at Ribs & Rumps Manly on Thursday June 28th.
The booking will be made for 8pm - and attendance must be confirmed by the 21st
Feel free to peruse the menu: http://www.ribsandrumps.com.au/menu.aspx :blink:
Ribs and Rumps Grill & Seafood: Manly
35 South Steyne Manly
Please Note:
This is not a free for all - If your name is not on the confirmed list, don't bother showing up. Pre-booking is required so anyone that thinks they can just rock up, will not be getting a seat.
Confirmed Attendees:
1. Blitz (Powered by Kobe Beef)
2. Sewid (LOL he thinks he can handle 1KG of Kobe!)
3. Beer Baron
4. Damuscat
5. DIF
6. Primordial
7. A31Deviat
8. Nathan
9. B-Man (Man of steel)
10. 4doorgtr
11. Smasha
12. Tosh
13. Kinks
14. Merli
15. Carlo
16. Mike1987
17. Moanie (No way......? :huh: )
18. tjandriesen
19. G3TFKD
20. Joeyz
21. Joeyz Partner
22. Smoky
23. Marsss
24. Liz
  • Replies 131
yeah baby, you know it.
should we allow b-man back in even though he's forsaken the lines? I think the last dinner he came to was at R+R manly. lol. that was a looong time ago.
Sounds good to me..... still haven't attempted the 1kg 'Mar O War', best ive done is the 500g... which isnt much of an effort, but backing it up with another 500g.... sheesh...
Haha D00dz eats more then that!
im in for sure! ill be man enough for the 1kg, if not corinne will help me finish wont you?
I don't eat steakkkk! If it was chicken I would be more then happy to take it off your hands :blink:
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
