Rump and Ribs i very tempting - might have to make a decision closer to the date, though.
So, after all these years, it was never decided on which "Team" I was on, is it TWS 'cos I'm near Parra and Blacktown, or TNS 'cos I'm equally as close to the Hills district?
Hmmmm, dunno... I've always liked Team North-West, and I'm sticking to it :laugh:
  • Replies 131
No worries, looking forward to the night out :laugh:
hehehe.. there is even a lil picture story to go with it!!!
someone needs to dig that up!!!!!! ;)
Hmmmm, dunno... I've always liked Team North-West, and I'm sticking to it ;)
lol! i've never liked it! it seperates the club! gheynesss! :thumbsup:
‘The bezht zhteakzh in the world. Thankzh a lot’
Dude, how many times must I tell you to pull the c0ck out before your speak?! :D
Hehehe isnt that the ones where donnie and the boys trying to rape Nicks new exhaust ? :blink:
Unfortunetly im still in exam mode :)
Havent been to a dinner in ages !! hopefully I can make the July one !
Oh and Andrew, did you end up getting the car you were talking about getting at frankys wedding ?
Edited by shonen
3 more days till the beef and beer injection bitches.
Booking has now been completed - Thanks to all those who confirmed :(
See you all there Thursday - bring an empty stomach!
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
