Wow - that's $300 bucks !!
Na, if your handy with tools, get your mates around and you should be able to do it in an hour or two.
Sounds like you don't have the C's spanners to adjust them?
Try and get hold of a pair of them (try whiteline), I think they sell for about 20-30 bucks each maybe?
All you do is lossen the rings and wind them down. Just amke sure you measure them all so you lower them all by the same amount.
There's a way of doing it with screwdrivers, but I've never done it that way...
J
wtf?
$300 to adjust the height of coilovers?
I'll do it for a beer. I would have said a 6 pack, but I'll have finished lowering the car before I finished one beer.
Seriously, get a C-spanner, and do it yourself, nothing could be easier.
Ron-15H,
Are your Bilsteins genuine, fully-adjustable coil-overs, or are they like mine, with a C-clip and some slots machined in the shock body to adjust the position of the spring platform.
The real point of (adjustable) coil-overs is not to lower the car, but to ensure that each corner carries the correct proportion of the car's weight.
Setting up a set of coil-overs in less than the time required to consume a tinny is not setting up coil-overs.
I had the spring treatment done on my GTS4, and frankly, it wasn't much chop. I ended up getting a set of lowered Kings springs.
If you have already lowered the car (you say you are planning to lower "another 1" "), then its highly recommended you don't lower it much more.
I'm sure you should find a couple of grooves machined into the shock body. If they are not there, then you should be able to get them modified appropriately.
Yellow paint does not a Bilstein make. (Old Man Emu off-road shocks are also generally yellow!). If they are Bilsteins, then they have "Bilstein" printed on the shock body. Why don't you have a look for yourself.
TOny, I think you are talking about rebound-adjustable shocks. That's not what the rest of us are talking about. There's no height adjustment in the rebound setting.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
