  • Replies 118
Posted Images
  • 1 month later...
Congrads man.......................... I live in merrylands so count me in bro...
i show some smoke for you on the day too
the reciption hall u off to had a nice straight
i have a Silver R33
Guys this definetly is still happening!!!
Im so overwhelmed with the huge response...
I have gone through some tough times and havent been on SAU for a while but I will update the list of people attending the drive by asap!!!
At this stage the focus is mainly on having as many people as possible do the drive by! :P
From 2.00pm - 8.00pm
At 2.00pm meet at Guildford for the service (photos to be taken)
At 3.00pm leave for city (The Rocks) for photos
At 5.30pm leave for Riverwood (Reception)
At 6.30pm-8.00pm More photos and video
(bridal party)
Hey mate im new but if ur still looken for ppl for the drive im in wouldnt mind seeing some of the other guys cars...
just to clarify is it 530 at riverwood or 530 leaving the rocks to drive to riverwood?
if its a 530 leave from the rocks and cruz to riverwood im definately up for that, i just couldnt b at riverwood by 530... ive got a gun metal r32 gtst...
congrats anyways mate
At this stage the focus is mainly on having as many people as possible do the drive by! :cheers:
Hi mate, im able to help out on the day. White R33 GTS-T. Just let me know.
Getting to riverwood by 6.30pm, leaving rocks(city) at 5.00-5.30pm! :/
Got ya down. :D
Guys I have updated the list of those who will be helping out.
A few changes have been made, there will no longer be bridal party cars.
Everyone is in for the drive-by as well as the drive from Rocks(city) back to Riverwood (Reception) if they choose to.
I have had to book cars for the bridal party as this needs to be set in stone and I cant afford to have someone pull out.
Once again I thank everyone that has put their name down and I look forward to getting many more cars to come along!!!! :/
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
