There's 4 very good write ups with pictures on this site. Everything is in them.
Take your time and take mental pictures or physical ones of everything you haven't seen before or are unsure of as it will help when putting it back together.
have the correct tools handy. Get a balancer puller that uses the two m6 holes to pull it off.
Melbourne, Northcote area. I have had a look at the step buy step procedure, I guess i am just not 100% in lining up the timing belt marks.
You'll be fine :) it's so simple. Wind it over and watch the cam marks and that they align, then check the crank. Done.
Question, once I have aligned the the marks for inlet,exhaust and crank, i then remove the tensioner, once the tensioner is removed / released ,will the belt want to move the cams from the original set location because of the tension lost ? if so how is this avoided or rectified?
one other question, just to clarify, the harmonic balancer retaining bolt is L/H thread or R/H?
Balancer bolt is normal thread. Righty tighty lefty loosey. There are a few ways to undo it.
Cams won't move, they're locked.
I'd advise looking at all Diys we have on this website and getting a good idea on how to do it.
Maybe someone here who is close to you can come and help too
People tend to stuff up the tension, usually too much.
Definitely do camshaft seals, and crank seal.
Yep I did, I guess?.
The gates belt is a LOT stiffer than the genuine and dayco belt, so at the same tension of the original, the gates felt a little loose. I did it up a bit tighter and it whirres
Just a quick question fellas,
I changed the timing belt on my r33 s2 det last night, all went reasonably well.. This morning i took if for a drive and every thing seemed fine until I entered the freeway and opened it up a bit, as load and pressure built up above 4.5-5 rpm + It seemed to bet a significant loss of power, now I would also like to mention that I have upgraded the turbo due to the turbo spitting it self the other day, the up grade was from standard - to a Garrett T3/T4 Hybrid A/C CHRA Conversion. (Car not tuned yet)?
is it a possibility the crank angle sensor could be 1-2 mm off even though i make it? or is it just running very rich etc..
I know this is not the right topic , a link to the correct topic would help or some insight would be appreciated.
Edited by Antek
I don't know much about that turbo. But have been in a few skylines with upgraded highflows and bigger turbos without tunes and they are slow and shouldn't be driven hard until you get a tune.
Did you mark the cas before taking it off?
Should check your timing with a light anyway because no mark will get it back to spot on. A small movement on the CAS is big in degrees, you could be up to 10' out? And that makes a huge difference as well, even 5 is easily noticeable.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
