Hey guys,
I just got a full service done for my r33 gtr and now i feel that it has lost power and response.
So basically i got all the oils changed, fuel filter, spark plugs, etc.
The boost seems to be normal and all but there is a noticeable power loss right through the rev range. The only thing it could be is the spark plugs?? But its really smooth. Any ideas???
Thanks
https://www.sau.com.au/forums/topic/169546-loss-of-power-after-service/
Agreed, timing, see if they adjusted the handbrake, its a long shot, but not impossible.
Well i did ask him to check my timing belt, but my car is stock standard? When you remove the cover can u adjust the timing??
They remove the crank angle sensor to check the belt. So yes if they didnt put it back in the original spot your timing has been changed.
When they take the cover off, they have to adjust the timing, check the CAS at the front of the exhaust can, and see if the mounting bolt witness marks from where it used to be are different to where it is now bolte.ie: it has been rotated(probably clockwise)from where it previously was.
If they used a much thicker and/or cheaper oil than what was in it before that could be the answer, but i'd guess spark plugs are more likely to be the culprit. Find out what plugs and what oil they used, and post it up.
Yes.. If they haven't dropped a timing light on it and guessed where it was prior it may very well be running either less or more ignition.
Hmm so I asked my mechanic today if he touched the CAS he said no. And he said he put in the same type of platinum spark plugs i had in before. And he reckons it feels good and there is nothing wrong with it. But then sometimes when i drive it, it does feels good and other times it doesnt feel as quick. Maybe its just me paranoid! But I am pretty sure its lost a bit of response down low although the top end feels the same.
Could it be the spark plugs not gapped correctly? But he was saying that it would run like crap if they werent gapped properly.
Is it possible to adjust the ignition timing without a dyno to give bit better response without damaging my motor?
Or maybe i should just accept the fact that its stock standard and the exhaust is restricting it lol.
Sounds like a bit of paranoia creeping in haha :)
Although, i would be using just a normal set of coppers gapped @ 1.1 for a stock GTR
Plati, Iridi etc. Just a waste of coin. The good ole coppers for less than $20 a set win hands down everytime.
- You might have a slightly dirty AFM, or loose perhaps.
- Maybe the coils dont have a connector on firmly, or similar across the other connectors
- A cooler pipe might have a slight leak, although it doesnt sound like that.
Basically, anything he needed to remove/touch for a service you need to follow and have that checked.
Its just retracing the parts he removed as one of them possibly isnt sitting right/the way it should
Will coppers make that much difference? I am planning to slap an exhaust on it soon.
Well I seem to get good boost response according to the stock guage, full boost a bit before or on 3k rpm i think so i dont think cooler pipe would be loose?
I will have a look at my afm, as he did remove my airbox and cleaned my panel filter.
Coils havent checked but will open it up and have a look.
so did he actually check your timing belt? Cause if he says he checked your timing belt and didnt touch the cas hes talking bs. Pop your hood and have a quick look at the cas, it has three bolts going through it. If you can see marks where the bolts used to be before then you know that it hasnt been set back in its original postion and if hes retarded the timing abit you will notice a difference. Ask him to put a timing light on your car and see what it is set at, if he knows what he is doing it will take less than a minute to do.
In saying that, people get paranoid when they hand their car to other people and start "noticing" things that they did see before haha
also how did he clean your filter? is it a k&n filter that he has re-oiled? The oil used on those filters can affect our afms..
He said he didnt open it up to check my belt. so that hasnt changed at all. I have got a HKS air filter i just had a look and it looks clean and the afm looks good too. The only thing is the spark plugs! because normally i feel the most power come in around 4000rpm and levels out a bit at higher rpms, but now it just feels pretty linear all the way through without the sudden power kick in. Had to explain!
Wild thought - you said AFM (singular) looks ok. You have got 2. If one is playing up the airflow reading to the ECU will be low (averages both).
Or maybe a bit of paranoia - now just go check under the bed.
I always get the same feeling when I get my car serviced. Not just the skyline, but every car I have had. It's weird, the car feels smoother and nicer but slightly slower. I ended up deciding it was all in my mind. it is interesting that you say the same thing.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
