hey all
got a new set of rims measuring 17x8 front and 17x9 rear.
whats the best street tyres to get at the moment?
im thinking 235/45/17 at the front and 255/45/17 at the rear but ist possible to have 265 or even 275 for the 9" rear rims?
its a daily driver so im not interested in street legal semi slicks.
yeah which brand and model tyres would you recommend?
say for a budget of around $1500.
any advice is much apreciated. thanks.
Edited by BaysideBlue
https://www.sau.com.au/forums/topic/169619-widest-possible-tyres-on-17x9-rims/
you can fit 265's onto a 9" rim no problems. However it won't provide you with as much latteral grip as a 245 or 255 tyre as there will be a lot more flex in the tyre due to the way it fit's onto the rim.
your idea of 235 fronts and 255 rears is perfect IMO.
for which tyre best suits read the tyre thread at the top of this page :)
depending on brand of tyres you go for you may be better off going for a 225 on the front and a 235 on the rear.
if you go for cheap brand tyres then go for a 275 rear, it will fit.
but if you go something quality like a S-03 Bridgestone you will only need 225 front and 235 rear
i have 265 on my 9" inch rims looks good as far as handling goes I'd probably go 235 or 245. I picked up 265's for 160 each there federals so not the best tyre but good price :) be careful if you go 265's companies try charge you through the ass as the tyres are hard to come across
Why? why not go 235/255 with good tyres, why would you get skinnier tyres when you go to a better tyre? ontop of the fact 225's on a a 9" rim look retarded.
I've got 255's all round on my GTR with 17x9 rims. perfect fit, tyre lines up with the edge of the rim exactly.
i also have 255 all round on 18x9 and they are spot on tyre fit i reckon
I would go a 225 on the front and 235 rear. or if you want you can go 235 front and 245/255 (depends on availability).
Amongst my cars I've had:
235 all round on 9inch rims (GTR)
245 all round on 9 inch rims (GTR)
255 all round on 9 inch rims (GTR)
235 all round on 9inch rims (GTST)
225 front (i think, they may be 235) on 8 inch rims and 255 rear on 9 inch rims (soarer).
the 255s are ok on the 9, but I reckon 235 or 245 will be better (a lot depends on tyre brand though).
If you are putting them on a skyline and you dont want your speedo to be out the closest match to stock (205/55/16 225/50/16) is 255/40/17
245/40 is close as well but 245/45 is by memory 3.3% too fast.
I currently have 245/45 but have always in the past had 255/40, i think this is a better size than the 245s which have a taller sidewall but get slightly stretched across the rim.
I believe stock r33gtr is 245/40 but most owners just replace with 245/45 due to availability.
265s usually bulge out a bit on 9inch rims, doesnt look good IMO and probably allows for a bit more sidewall flex.
Read the tyre thread for opinions on tyres. With that budget you can get top of the range street tyres so it just depends on what compromise you want.
sure...:rofl:
I'm running 17x8 on the fronts and 17x9's on the rears .
optimal tyres settings I've found so far are 235(45 profile) fronts and 255(40 profile) for daily use.
I guess it also comes down the design of the sidewalls and the profile. I'm running Bridgestones Potenza S-02's (best tyres ever!) on the rear which have a great sidewall and tread pattern to suit wide rims (I've had 2 styles of S-02's so far and the 1st pair of 255's stretched over rims more while the 2nd pair sat evenly without stretching, Later on I found out the S-02's were designed for specific cars, 1st ones were for a Porsche 993 while the 2nd was for a HSV).
You should also really take into account the offset of the rims your running too, against the tyres your thinking of putting on otherwise you may risk rubbing your guards.
Hope it helps.
Edited by Jenius
its been covered but still to 255 on the rear, i had 9" with 255 and suited to the ground, and now i have 275 on 10 which is just as good....you dont want to stretch it, just get a wider rim.....go the 275's
225/50/16 112.6 sidewall (406mm wheel + 225mm = 631 diamter)
255/40/17 is 102mm (so total diameter would be 17 inch 432mm + 204mm = 636 diamter)
245/40/17 has a sidewall of 98mm (432+196 = 628)
245/45/17 has a sidewall of 110 (432+220=652)
so the closest to stock diameter is 245/40. but to be honest speedo accuracy has never bothered me a bit. the speedo is only accurate to about 10% to begin with anyway.
and no, standard 33 GTR size is 235/45/17 not 245.
Yeah ~3% is not enough to bother me either which is why i went for the 245/45s... and as you say speedo only has to be within 10%, but i dont believe that the stock 33 gtr tyre size is 235/45/17 i am sure it is 245/ either 40 or 45 as mentioned by t04gtr.
Speaking of wrong compliance stickers i have one on my own car, it states that 255/40/17 is a standard size.
seems I could be wrong. I was just remembereing the japanese sticker on the door jamb on my 33 GTR, BUT my memory is not that flash. I would say that call was 50% memory, 50% talking out of my arse.
Is't a good time to get Bridgestone S-03s? They are due to be replaced soon and are on special at the moment.
I've got a quote for 255/40ZR17 94Y $410 a tyre
and 225/45ZR17 91Y $305 each
both rolling diameter 636mm
in terms of price and performance, are there better value alternatives at the moment?
cheers
cheers
I think that all the higher end bridgestones are overpriced, and if those prices you quoted are 'specials' then that proves my point :P
There are a few similar tyres that you can get for a fair bit less. Dig up motor magazine tyre test but off the top of my head but if i were looking at that type of tyre ring around for:
Dunlop sp-sport maxx
Falken fk-452
Falken rt-615 (higher performance worse treadwear)
Goodyear Eagle F1 GS-D3
All of those tyres have similar performance to the S03 but cost less.
Tempe has the 615s in 225/45/17 for ~$275, and you can get the sport maxxs for a good price right now from a few places in 235/45.
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
