Probly a repost but for anyone that hasnt seen 300bhp in a 500kg car its a must watch.
Random 100 ton munitions explosion.
This one always made me think.
I found this fasinating,anyone interested in war time technollogy will love this...its very long tho,be sure to watch all the parts 1 - 6
In WW2 this was the worlds largest railgun built by the germans apparently.
That is all for now :P
name="allowFullScreen" value="true"></param><param name="allowScriptAccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="425" height="344"></embed></object>&">
type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="425" height="344"></embed></object>&" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350" />
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
