wheel nuts have nothing to do with the actual wheel hitting the caliper.
I never said they did?
But they do have everything to do with the wheel nuts coming loose after a short drive as DjeMz has stated.
Use stock wheel nuts DjeMz, quite possible the aftermarket wheel nuts are not suitable for the wheel type.
Thanks dude, ill give nissan a buz n find out how much..
Any ideas on where else i can get stock nuts?
strange! I just tried to fit a set of 34 rims then to mine..
won't fit on the front.. and will need a spacer of about 8mm (spacers are illegal btw).. Only thing I can think of is that I fitted a new set of brake pads a while ago, which maybe the increased meat in the pads pushes the caliper that much further out?
X-files??? :)
pitty your not in sydney id suggest going to tempe tyres, i got home weird ass aftermarket nuts from them that fit my wheels perfectly
any wheel shop that fits shitloads of aftermarket wheels should be able to help u out
Please tell me you are joking !!
  • 4 weeks later...
No issue with the rears at all.
I put r34gtt rims on my r32 with stock (280mm rotor) mspec calipers and they hit the inside of the front rims.
It's well documented that they won't fit straight onto r32s
I had been told I'd need a thin spacer but i didn't understand why until I tried to fit the wheels.
The issue is not that the calipers are too far out and hit the back of the spokes as I thought but that they need to be mounted further out from the centre as required for larger rotors.
8mm spacers won't leave enough thread for the full nut to screw on.
I fitted 3mm spacers to the front which gave it clearance until I found some cheap r33 calipers and rotors.
These give clearance without spacers but it would be better to fit r34gtt (310mm) brakes as the r33 (296mm) brakes give less than 1mm of clearance.
  • 4 months later...
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
    • It always seems the uglier an animal is the more is costs
