Hi all just a simple one when im reving my car out at about 5500rpm this orange light lights up on my dash saying "check" it only really flashes on and off but still comes up. What is it? I've included a pic so you know which one its the yellow one in the top right.
https://www.sau.com.au/forums/topic/170232-what-does-this-light-mean/
Your engine is knocking, it comes on with a knock reading over 60. Get your car looked at immediately or you could do serious engine damage. Could be caused by poor tuning, bad fuel, bad plugs ect ect.
Edited by fEkuaR
exhaust, z32 afm, apexi pod, power fc, fmic. But i had to reset the the power fc so its running untuned at the moment. Do you reckon once it's tuned it should be ok?
yes. have you selected the Z32 AFM in the menu (if you have reset the STD AFM will be selected)...it may cure the problem...until properly tuned.
the engine is seeing more air than the Z32 is indicating (its probably set up for the STD AFM)...hence the injectors are not putting enough fuel in your engine. The power fc should run rich with a base map with the Z32 selected so should be nice and safe.
it might not apply here, but turning OFF the optional boost controller on the pfc off sounds similar to what you're describing.
on the hand controller, go to:
Etc mode
Function Select
Boost Control Kit
then opposite to whatever its on now (it will be in japanese).
if it doesnt work then change it back.
Etc mode
Function Select
Boost Control Kit
That leaves the light on all the time and in some cases the car won't start (probably dependant on firmware version).
no... my mates r33 had the same problem after he reset his pfc. only came on under load past 5k.
Funny how it would detect that the boost controller was not there all the time but only display the fault after 5k rpm under load on a base tune.
I'm only going off what my PFC does and what's in Paul's PFC FAQ.
Etc mode
Function Select
Boost Control Kit
In my experience the car wont even start with the boost controller setting set ON if it's not plugged in.
As for the bloke's original problem, I think running around with the base PFC map is a pretty bad idea. It's designed so you can putt it to the tuner not so you can drive the car every day. The fact that you don't even know what a check engine light in is even scarier... Take the PFC out and put your stock ECU back in before you cost yourself thousands of dollars when you have to rebuild your motor.
Either that or stop driving it until you can tune it... its not rocket science...
im 100% sure it does what he is describing with the BC setting on. my mates did it after a reset as i mentioned. i went through the settings to turn it off and it doesnt do it anymore.
it is just a thought anyhow, if it doesnt work for him then move on.
guys, its the knock reading on the power fc going above 60. the first reply was correct.
if you go to monitor, and select knock as one of the channels, then press right so it displays the maximum you have reached on the right side of the screen. rev it out and watch the little light flash, then look at the max value you have reached.
i guarantee its more than 60. this is why you need to tune the car, to stop the engine pinging and get it running healthily. go now and do it lol.
I recently got my Power FC installed in my R33 GTST. I had the same problem to start with but the light stayed on all the time not flashing. This was because my boost control warning sensor was turned on when i didn't had the boost controller kit.
when i was on the high rpm like 6000, the engine check light started flashing as the knock reading was like 89-97. So i had to take my car for dyno tuning again. If you are getting the high knock reading, Check your map on the power fc and locate the point on the 20*20 cells when the light flashes. You have to reduce few degrees on the timing from that cell and the neighboring cells as well.
I am still getting same problem but its not due to knocking, its AFM as my stock AFM is maxed out.
Tuning should fix your problem.
I took car in today to have it dyno and the guys told me, your car is running TOO LEAN.
What does that mean/ Can effect will it have on my engine, car because I will not get to the tuner shop til Friday?
I have these mods, TM boost control, POD of some kind, split dump pipe, full exhaust with 3" tip, Axexi Power FC and a FMIC.
Any and all helpful answer are cool.
The one dyno run at 13.5 PSI was 194 rwkw.
  • 1 month later...
That light wont come on till 78 knock on standard skyline so its actually quite high from factory not 60, anything under 60 once you get it tuned is desirable and what tuners look for, it wont detonate on the first ping but if u continue to drive with it contiually pinging it will go bang....
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
