Its "blue" off R31 site i believe. I havent seen the finished pics though... im a bit behind with it all.
Its not mines tunes though, its just a sticker. I dont recall MINES coming out to AUS recently to tune any car.
Also it isnt exactly stock weight from memory!
And lighter you are, the faster you go, meaning you dont need a big budget power motor :P
Also helps if you can drive and have the car setup well
Incorrect Ash hehe .... he;s never taken he;s coupe out of vic....
its another car
blues car is yellow as well though....but slightly different.. still running a ECCS redtop 20 at that..... (my old engine from my coupe)
http://forum.r31skylineclub.com/index.php/topic,42608.0.html check it out .. she goes pretty well now
Matt
Kelvin Maxfield is the owner, nice guy and a tidy steerer. He's based on the North West Coast of Tassie.
Used to race an FJ20DET powered Datto 1600.
Just over 300kWs at the wheels I am told. Not sure about Mines tuned, but its seen a fair amount of time on Pro Automotive's dyno of late.
Edited by t01-100
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
