Hi guys
after alot of discussion i had with the gt3540, i ended up selling it as the rear housing was going to be too big for my liking on the street.
So changing my mind every 5 secs, i went with the gt30r turbo, having it high mounted, wide mouth dump, 44mm external wastegate.
With ppl that "have" done this setup, whats the go with putting on a braided water return line (runs from the back oof the block) ?
Can it be cut and a connector go onto the existing water line, or does it have to be removed altogether and put a whole new braided line on, hopefully this makes sense. Just looking at the water line, im trying to figure out how ya get the friggin line off?
Also, ppl that have gt30r with the .82 rear, what power have you made on your r33, ( i was going through the rb25det upgrade page, but most ppl dont specify what rear housing they have, and just want to know if ppl are making it close to the 400rwhp.
Also if you have pics of your high mount setup with this turbo, and any altercations along the way, that you had to deal with?
I have all fuel mods done, FMIC, AVCR, Z32 afm, 3" exhaust, with hiflow cat.
Also considering cams later on after this has been done
Thanks
https://www.sau.com.au/forums/topic/171235-gt30r-upgrade-to-r33-gtst/
Yes you can cut the steel pipe and fit olive fittings.
The turbo is capable 350+ rwkw but don't think a stock motor will let you achieve that type of figures.
If you do get the turbo, go for the v-band exhaust housing.....everything else is straight forward.
sweet as, thats what i needed to know
would a person that deal with making custom braided oil and water lines, know how to do this?
i will be looking at getting cams later, hopefully, but if engine goes bang then rebuild will be last resort
Yeah some like enzed or pirtek will know what to do.
Are you 100% sure mate this turbo would be caperbale of 350rwkw with only a .5 front cover?
sorry mate but there is no chance it will make 350rwkw. They aren't big enough. And they certainly won't do that with a 0.5 cover.
Paul you would know better than many/most that all GT30s are not created equal. It covers a HUGE range of mass-flow and performance capabilities. Just because Ash achieved such a large figure doesn't follow that everyone will.
The 0.50 comp cover tells us little about the compressor ASSEMBLY. What size impeller is this thing running? Off the shelf you can spec 71, 76 and 82mm, with a variety of trims and specs. And assuming that it has the 60mm turbine rotor, what A/R is the turbine housing?
The only thing that is a certainty is that the specs of each side will determine the mass-flow throughput potential, and efficiency. But it will be the TUNE that determines ultimately what it makes :D
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
