We'll all get in. Saturday will be half empty (it always is) and they have a big field on the Sunday (120 usually - remember they send out 24 cars on the track at once with PIARC).
Over the 2 days you'll get plenty of clean laps but there will also be a few laps of door to door fun to be had as well with fields like this. Especially since PIARC don't group cars according to lap times so you can get some big differences in speeds (but we can all put our names down in the same group so it is no big deal).
And good luck getting Benno to PI even though it is a Sunday and so he has no excuse. Maybe if we all say his muscles are under developed (or at least the important ones are) we might be able to coax him into it. But I'm not saying it cause I still need him to look after my car :thumbsup:
  • Replies 263
Posted Images
I'm sure the car could do it. The problem is all you northern franginpani loving poofs are so used to driving around on your dinky little racetracks with tops speeds of 87km/hr that you aren't going to know what to do when you run out of revs in 3rd.
But I'll help you out Pete. Just remember the advise you gave me at Wakefield and use it at PI. "Keep it flat through turn 1 and you'll be right. If you lift off you are a poof." :dry:
LOL...you havent seen the footage of Fatz at "The Ring" ? I think most corners were flat ! :sick:
That, combined with my understandign of how much he loves his piss, especially when its free. Well he wont let a little thing like lack of willing car stop him from being showered with free beer for his display of lunacy. Not like Victorians, who like being showered in other things golden...farkin twisted units! :dry:
But I'll help you out Pete. Just remember the advise you gave me at Wakefield and use it at PI. "Keep it flat through turn 1 and you'll be right. If you lift off you are a poof." :rant:
lol :(
I remember that advice myself, among many other interesting points
So, how fast through turn one, with and without 2/4wd/ aero aids? Seriously, but I doubt anyone goes more than 200, the rest is piss and wind :rofl:
Aero aids? Farkin Geezus...what? Fast enough that the id blow through the wall on the infield as easily as my troopers punch through a prophylactic :rant:
BTW - You're all a bunch of girls.
Especially you Bris!
Hope you have a healthy back! Because your going to be doing plenty of bending over picking up your teeth after this girl knocks them out :(
So, how fast through turn one, with and without 2/4wd/ aero aids? Seriously, but I doubt anyone goes more than 200, the rest is piss and wind :rant:
Depends how big your balls are...
4wd doesn't help you get around the corner any faster, it just helps you get out of the corner faster... the rest is in grip and suspension. On street tyres you may do 170-180 entry, on R comps, probably 190-200+ - like i said, how big are your nuts?
Im bringing the trolley jack and stands. So that means GTR drivers should bring armed security. Turn your backs for a second and your cars will lose the front driveshafts and an AFM will probably be unplugged as well.
Or my old favourite. When you have parked your buckets after the first session i will poor some oil under your cars so you all shit yourselves and park it for the day. This day shall be mine i tell you...MINE!!!!!!!!!!!!!!!!!!!!!
HEY!!! who's idea was that!! :)
This thread has to be one of the most entertaining one on the forums!!!!
I'll definetly be there for this, but probably only the Sunday, don't need the Saturday practice... :)
Go Jack and this is going to be the biggest track day in Australia ever for GTR's and others. How many sleeps left???
I can't wait. Hey Jack I will follow you to learn this track which I have been playing over in my mind since I was there in Easter. I will then give it the button on the straight with the boost turned right up this time. I reckon with good condition and the bigger rear wheels and suspension geometry mods and more I will be 45's or better.
I've heard you hit like a girl anyways... My teeth will be fine! ;)
Hope you have a healthy back! Because your going to be doing plenty of bending over picking up your teeth after this girl knocks them out :domokun:
John - we'll see if we can get Frank and Kennedy down who have both run in the 43's before (both R33 GT-R's). But I'm also going to be gunning for 45's.
Also mate - we're coming up to Wakefield and EC on November 8th and 9th respectively.
http://www.skylinesaustralia.com/forums/in...howtopic=176741
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
