i got epa'd with my 25.. was fine :thumbsup: no engineers etc. But back to the topic.. roy got ~260@20? with his td06 and i know legend has 300 but i dont know at what psi.. if a highflow can get around 240 you could be looking at 250+ but at like 20+ psi
i checked out all the rb20 upgrades my car will run 22 23 psi easy with the rebuild
i have a wolf ver 5 its top of the range for price good tune will get 23 psi
all cars on the rb20 upgrades with exact turbo gt30r with 0.63 are peaking at 380hp 283.3rwkw
Nothing less than that??
i should pull it easy.
i will comfortably run 260rwkw at 18psi
With almost same mods most with out the flow of the head.
GT30 FTW!!!
AH Ha ha ha ive got the best in the business mate...
ROB from sabbin auto AND PETE From RANK ROTA
They just merged company's they are both in the same workshop workin on my baby
RB20 Monsta on the way
Whats that comin over the hill???
Rob and Pete are top blokes, great mechanics and pretty good tunners of the Wolf :whistling:
Pete tuned my car on several occations, years ago, before EAS got their own dyno, but i never met him personally, as my mechanic would drive my car there and help Pete tune it. I know Rob, since my frequent clubbing days, when i used to go to Icon :P.
Personally, i would only use 20psi max on pump fuel, due to the companies' inability to provided a consistant quality of fuel.
280kw using a GT30R(450hp) is pushing the envelope, but acheivable as i made 260rwkw@18psi with a HKS GTRS, only time will tell. I take it you are using the .63 exhaust housing, as i too have a GT30R rated at 500hp with a .82 ext housing. This will be fitted to my new engine.
yeah your probably right maybe i should only go to 20psi tops then
500hp gt30 .86 thats pretty big you will get lag but massive top end
my turbs is much like the gt3040 the compessor wheels and stuff are different
i got another mechanic to look it up for me he said my turbo is probably even too big for a 2.5lt
whateva the go im happy with 250kw reliable. thats all i want i can drive it like a baby and the power is there if i want it
you cant do much on our roads anyway with the new laws so i just save it for the track
dyno numbers mean fark all.... it's nice to say 'my car makes 350000kw' but remember dyno numbers are only a tool to see the relative gains and to make sure the tune is right.
i would rather have my car make 100kw then after mods make 150kw, that way I have a 50% increase in power. As long as it drives well and feels fast before and after, doesn't matter if the number says 100 or 500...
get it to the track (circuit or drag) and see what times it will do!!
and have fun when you get it back :P
PS Al - spill it mate... what's the go on your motor??
rob recons with a tune on race fuel if i wanna race the car it will easily run 30psi
WHOOOOOO
he recons close to 300kw itsnt hard to get on race fuel and tune
he can have two setting's or something on the ecu one for racing 30psi race fuel
and 20 psi on pump fuel
and brisby yeah i think i will get shocks springs ect when ive got cash again i just bought a house so im basically broke AGAIN
LOL... THATS IT NOS IT IS THEN. in Maybe ten years.
if i live that long with this power.
I spoke to rob and its gonna cost too much for the CAM ect so im not doing it anymore
but im still flowing the head forgies rods plenum and new clutch ill see how that goes other stuff can wait. i wonder how long it will take for him to build he said 4 weeks but we'll see..
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
