  • Replies 539
well im happy with anything higher than what i had be for i started 310+..my biggest problem now is that the exhaust manifold that i was going to use is only good for beating the guy i got it from to death and maybe one or two other clowns. hopefully he will send me one soon that will fit.
when u get the manifold - we'll fit it up! now dont ask me if i know what im ok MKAAAAY!
ive had it like this for a few years now i just got it re done. my cousin did it from akcartooning.
http://www.akcartooning.com.au/
http://www.myspace.com/akcartooning
http://www.facebook.com/pages/AK-Cartooning/119294988087618
Doubting what existed?
and what are you doubting
anyway took the car out last night and its off its head, again its got no lag at all it sounds great goes great,its a perfect combo once you do the right mods in one package just like i aimed to do all along in stages its .................Fu$%en goooood.
Edited by WARLORD
your car is a handful & i actually think it has too much power now nick - then again, you are asking someone who has an awd.
3rd gear @ about 3500-4000rpm...it starts breaking traction VIOLENTLY! this would have to be @ close to 100km/h right and its running 255's on the rear as well!
Im sure it would, but you can't beat awd for traction.
What tyres are you using warlord? also can we get a street video? I want to see how insane this car is.
m/t streets 255 for drag and kumoh for street, there are vids of my set up from be for look at earlier posts for the links,
  • 3 weeks later...
small update
ran the car on the dyno to make sure its safe the way it is with a very small tweek befor crd tune it,so far the car made 110 nm more and 65kw more in the mid range so it will be very interesting to see the end product.need to mod the exhaust a bit and get a larger cat. a set of ku36 on the back will help the traction problem to i hope.
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
